Speed Signal Wire
Old May 23, 2004 | 09:22 PM
FX GS's Avatar
FX GS
Default Speed Signal Wire
Looking for the speed signal wire coming out of the PCM on a '96. The four connectors to the PCM are marked on the PCM as (on the top of the PCM)
black and red and (on the bottom of the PCM) gray and blue.
The speed signal wire is supposed to be the dark green w/white stripe.
Does anyone know out of which connector this wire comes out of?
Old May 23, 2004 | 11:06 PM
tjwong's Avatar
tjwong
Default Re: Speed Signal Wire (FX GS)
The PCM receives its speed signal from the VSS sensor, that sensor is connected to C1 (red) pins 31 (purple) and pin 32 (yellow). The speed signal output to the CCM and Cruise control system is locate at C2 (black) pin 8 and is the dk grn/wht wire.
