Fixed my ticking
Old May 27, 2004 | 09:17 AM
dave_85's Avatar
dave_85
Default Fixed my ticking
Well the ticking is finally gone. :party:
This is what I did to fix it. New Pro Topline 180/64cc iron heads, full roller rockers and push rods. The new heads needed longer push rods. The only problem is I don’t know which part was causing the problem. I suspect the valves.
Before it tore into it I narrowed it down to number one intake by listening
to it running with the valve cover off. I tried to adjust it when it was running.
I could definitely tell when I backed it off that I got to zero lash but adding
half or even one turn did not get rid of it completely.
I did not change the lifters.
Old May 27, 2004 | 10:19 AM
bogus's Avatar
bogus
Default Re: Fixed my ticking (dave_85)
:hurray:
Old May 27, 2004 | 03:05 PM
JAKE's Avatar
JAKE
So you're saying that you went with longer pushrods and that solved your ticking problem, right?
How much longer? What preload did you end up using?
Jake
Old May 27, 2004 | 03:21 PM
dave_85's Avatar
dave_85
Default Re: Fixed my ticking (JAKE)
No. I am saying changing all the stuff fixed it, but I am not completely sure what part did the trick.
The heads have longer valves so I needed longer pushrods. I included it just to be complete.
To Fixed my ticking
