Headlight Prob
Old May 27, 2004 | 01:21 PM
Pappa_Bear's Avatar
Pappa_Bear
Default Headlight Prob
Last night I heard a knock-knock-knock coming from the hood after I pulled into the garage. I figured it must be the horn problem I was having before coming back. I opened the hood and it wasn't the horn, but the passenger headhlight motor knocking and the the cap on the end turning 1/4 turn each time.
I turned on the headlights and they rotated open fine, but when I went to turn it off, they started really slow and the knocking sound was back. So I left them open and disconnected the wires to each. Right now I'm running with the lights rotated open and would like to know exactly what the cause is before I go off ordering $5,000 worth of parts just to find out it's only something minor. I know the previous versions had problems with gears. So...what could it be my C4 Friends? :conehead
Old May 27, 2004 | 02:24 PM
JAKE's Avatar
JAKE
Default Re: Headlight Prob (Pappa_Bear)
There's another headlight problem post that you should take a look at. It's on the first page of this board. http://forums.corvetteforum.com/zerothread?id=829001
Also, the 'TOOLS' "Tech Tips" section on this Forum has lots of info that can probably point you in the right direction.
Jake
[Modified by JAKE, 1:25 PM 5/27/2004]
Old May 27, 2004 | 02:33 PM
cutchy's Avatar
cutchy
Default Re: Headlight Prob (JAKE)
Pappa bear
You have three delrin bushings inside the headlight motor gearbox that have become powder. Fairly cheap from Eckler's but your in for about 2 hours of work for each headlight. Might as well do both while your at it. The second one will be easier than the first. There is a lot of info on how to change the bushings. After having done several of these my first advise is to use a scribe to mark the mounting points of the head light assembly before removing it to the bench. Makes realignment a snap. :cheers:
http://www.ecklers.com/product.asp?p...MAGH9UFD9N2W9D
Old May 27, 2004 | 03:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Headlight Prob (cutchy)
Try to move the headlights with the manual *****; if control feels "mushy" replace those three nylon bushings.
Old May 27, 2004 | 03:30 PM
QuikZilver's Avatar
QuikZilver
Pappa bear
:iagree:
Definitely a bushing problem! Both of my lights did the same thing. I upgraded my plastic gear to the brass gear. It is a pain sometimes to get the plastic gear out without damaging it to get the bushings in. You may want to look at getting at least an extra plastic gear ($25 at Ecklers) just in case you have to dig into one of the gears to pry it out.
:cheers:
Old May 27, 2004 | 07:07 PM
Pappa_Bear's Avatar
Pappa_Bear
Default Re: Headlight Prob (Whitvette)
Thanks guys. That's what I was thinking myself. Wanted to check before ordering...
To Headlight Prob
