Alarm keeps going off!
Old May 28, 2004 | 09:43 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Alarm keeps going off!
Still having problems with alarm system...I thoght it might be the door lock sensor, but I have discovered that the alarm will go off if either door is opened, whether the door was locked or not. any ideas?
Old May 28, 2004 | 11:12 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Alarm keeps going off! (ir0nmaiden420)
When I had that problem it was because the light switch in front of the driver door wasn't being depressed firmly enough.
So, I taped a thin piece of Al onto the front of the door to fully depress the switch and problem solved.
To test your problem, close the doors with the alarm off and see if the interior lights eventually come on.
