A/C clutch doesnt come on automatically
Old Jun 8, 2004 | 08:00 PM
kdcollins's Avatar
kdcollins
Default A/C clutch doesnt come on automatically
Greetings Great Ones.
Had A/C issues for some time now. Spent some loot and purchased the HVAC programmer, HVAC electronic control panel and the high pressure switch on the 89 L98. Juiced it with freon and the A/C clutch wouldnt come on. Shorted the high pressure switch, still no compressor response. So, I grounded the green wire going to the clutch just so we could fill'r up on freon while I had the chance.
When I push the BI-LEVEL button on the control panel, I get fans, I get higher RPM's and I get air, but no cold air, I check the clutch and it isnt going. No matter what the scenario, no clutch.
I tried leaving the wire grounded and the clutch engauges and runs and does a good job, but then it never shuts off. Never. So, I disconned the grounding I had connected.
All appears well, just no clutch engagement.
Any idea???
Old Jun 10, 2004 | 10:14 PM
87NassauBlue's Avatar
87NassauBlue
Default Re: A/C clutch doesnt come on automatically (kdcollins)
Check to make sure your clutch is getting voltange or not. If the front plate is out of adjustment, the magnet can't pull it in. It could just be a mechanical adjust ment on the clutch
