Turning Over but not Starting - Chapter 2
Any ideas out there
Well you have fuel, spark and are reasonably sure timing is close. At this point I would run a compression check on a cylinder. This will show if valve timing is ok.
If you remove the plenum & runners, unbolt the fuel rail and unbolt the fuel lines from the block it's possible to remove the injectors from the base. Then you can apply fuel pressure to the rail and look for a leaking injector. If not you might turn the engine over with the key to see if all the injectors are firing.
If these tests pass, pull the left valve cover, all the plugs and manually turn the crank till the intake is closing. Then insert a screw driver into the #1 spark plug hole and slowly turn the crank (CW) till you see the screw driver move (you are using it as a piston stop). At this point the piston is very close to TDC on the compression stroke and the timing marks on the damper should be close 6deg BTDC.
Though some effort is involved in the above tests, you should be able to isolate the problem without throwing any more $$ at the problem till after you find the problem cause.
Also check to see if the vats system is working, it may prevent start up..
[Modified by korvette4u, 11:59 PM 6/15/2004]
Try these:
Attach a timing light to each of the spark plug wires, crank the engine and see if the timing light flashes. You should see regular flashes when the light is connected to each plug wire.
Use a test light. Disconnect one injector connector, connect the test light and crank the engine. The test light should blink while cranking. Use a test light with a 6.3 volt bulb. If the test light blinks then the ECM is probably okay.
Disconnect the TPS and try starting the engine. If it starts, it's a bad TPS
Disconnect the MAF and try starting it; if it starts it's a bad MAF or MAF wiring. With the MAF disconnected the ECM will use a default value for the MAF sensor
Disconnect the EST by-pass line (single tan wire with black stripe near the power brake booster in a WeatherPak connector) if the engine starts, it's a bad pick-up coil.
Depress the accelerator pedal all the way to the floor, hold it there and crank the engine. If the engine is in Clear Flood mode, the engine may fire.
Without actually having to disconnect the fuel rails from the intake manifold, in order to check for a leaking fuel injector(s) you'll need to pinch off the rubber fuel hoses. First pinch off the RETURN hose, then the SUPPLY hose.
With a fuel pressure gauge installed you can see if the pressure holds when the fuel pump is energized and then de-energized. (turned on and off). After the fuel system has been pressurized by the activation of the fuel pump then turned off, the pressure should hold for a period of time.
If the pressure holds, you're in good shape.
Assuming no fuel leak from the hoses or lines:
If the pressure drops with the RETURN hose pinched off then it's either one or more of the injectors leaking or the fuel pressure regulator. This must be repaired.
If the pressure drops with the SUPPLY line pinched off, then it's probably the intake fuel pump check valve (which is no biggie).
Get back to use after making those tests and give an update.
Jake
Here is the results of test so far:
Thanks,
Tom
Tried two wire and saw the flashes on both wires - Attach a timing light to each of the spark plug wires, crank the engine and see if the timing light flashes. You should see regular flashes when the light is connected to each plug wire.
I have a question on this one, should the trouble light be lit when the key is turned on? I connected the trouble light to each socket of the injector plug, turned the key on and it immediately lit up, then turned the engine over and it blinked with each pulse I am assuming - Use a test light. Disconnect one injector connector, connect the test light and crank the engine. The test light should blink while cranking. Use a test light with a 6.3 volt bulb. If the test light blinks then the ECM is probably okay.
Car did not start - Disconnect the TPS and try starting the engine. If it starts, it's a bad TPS
Car did not start - Disconnect the MAF and try starting it; if it starts it's a bad MAF or MAF wiring. With the MAF disconnected the ECM will use a default value for the MAF sensor
Car did not start - Disconnect the EST by-pass line (single tan wire with black stripe near the power brake booster in a WeatherPak connector) if the engine starts, it's a bad pick-up coil.
Car did not start - Depress the accelerator pedal all the way to the floor, hold it there and crank the engine. If the engine is in Clear Flood mode, the engine may fire.
Need to try this tonight, however did this to start with nrmal results - Without actually having to disconnect the fuel rails from the intake manifold, in order to check for a leaking fuel injector(s) you'll need to pinch off the rubber fuel hoses. First pinch off the RETURN hose, then the SUPPLY hose.
When the key is turned on pressure will build to 40 psi and then the pump stop and pressure goes to zero. When I crank the engine pressure builds to 43 psi and holds for a while before slowly going to zero - With a fuel pressure gauge installed you can see if the pressure holds when the fuel pump is energized and then de-energized. (turned on and off). After the fuel system has been pressurized by the activation of the fuel pump then turned off, the pressure should hold for a period of time.
Jake
(Inj conn (other side) -> ECM)
"When the key is turned on pressure will build to 40 psi and then the pump stop and pressure goes to zero."
This is prolly the Fpump check valve (not a problem). Do the hose pinch test, to be sure.
"When I crank the engine pressure builds to 43 psi and holds for a while before slowly going to zero "
Slowly goes to zero,... while cranking,.. or after you stop cranking?
You verified the cap wires,.. firing order,.. right?
You verfied your cam/distrib timing right? (Timing gear worn out) (Timing chain jumped - Quick comp test will show this.)
[Modified by ZylaRace, 1:49 PM 6/17/2004]
When did this first begin and what were the circumstances?
Is this a fresh rebuild with the engine starting for the first time or did the engine just quit on you?
Have you had the distributor out or moved it?
Jake
I was checking out my car last night with a suggestion to check the distributor rotor for correct placement and it checked OK. However while I was checking the timing ( I could not see the marks that well with it turing over) I smelled gas again and it sounded like the rails were passing fuel like I thought it should. I deceide to check the dipstick and could not get a good level and it smelled like gas. I ended up draining my oil pan and got a mixture of oil and gas ... about 3 to 3 and half gallons worth. So I think my next step is to check injectors for leaks. Cruis-in II Veteran's suggestion
Thanks everybody I hope this is the light at the end of the tunnel,
Tom
Thanks,
Tom
[Modified by tommys88c4, 11:46 PM 6/18/2004]
Unplug the CSV's electrical connector. It only goes to the CSS and has no connection to the ECM, so it won't cause the ECM to set a code. See if that helps. If it does then the CSS is bad. If it is the CSS, you can follow the wires from the CSV to the front of the engine just below the throttle body and remove/replace it. If it doesn't help, the CSV could still be the injector that is stuck open, but you need to pull the CSV to test and that isn't easy with the fuel rail in place. At 88k miles I'm betting that you need to have the injectors rebuilt.
You cannot buy a new CSV, so you either reuse it as is or have it rebuilt. I recommend rich@cruzinperformance to rebuild all 9 injectors or just he CSV and install Ford Mororsport 24# units.
I I ended up draining my oil pan and got a mixture of oil and gas ... about 3 to 3 and half gallons worth. So I think my next step is to check injectors for leaks. Cruis-in II Veteran's suggestion
Tom
[/SNIP]WOW! You're talking about 12 to 14 quarts out of the oil pan. Are you sure it was THAT much? That's close to 3 times the amount that should be in the pan.
If it is anywhere near that amount, it sure sounds like you have injector leaks or problems with the fuel pressure regulator. I can't imagine that just cranking the engine without it firing could cause that much fuel to end up in the pan.
Jake
Yes, I could not believe I had that much fluid in my stock oil pan. I have been testing quite a bit so it is an accumulation since I first posted with my problem.
I have a reason not to try what another person wants me to try is starter fluid. Right now I have so much fuel in the cylinders I doubt starter fluid will help the problem.
I tested my Cold Start Injector and it was not leaking or pouring a lot of fuel into the engine. My next step is to try and test the injectors by pulling the plenum and fuel rails to see if I can 1) perform this test 2) find the culprit.
Wish me luck as always suggestions are appreciated,
Tom
You FPR is leaking into your plenum.
The engine is not starting, because it is flooded.
Pull the vacuum hose off the FPR. Turn the key to On. I'll bet you are getting a steady stream of gas out of the FPR vac conn.
Time for a new FPR diaphram.
