Dyno results Pre Procharger
Old Jun 24, 2004 | 03:15 PM
  #41
h rocks's Avatar
h rocks
Default Re: Dyno results Pre Procharger (CTYANK2)
"Maybe if we all think positive it will work out well!"
...and only six more months 'till Santa!
Old Jun 24, 2004 | 05:27 PM
  #42
Hammer's Avatar
Hammer
Default Re: Dyno results Pre Procharger (LT1Vetteguy78)
LT1Vetteguy78,
Have you visited the shop since you dropped it off? If not, do it ASAP. I just went a YEAR getting a motor back together. Stuff you never think of happening, happens.
You need to expect a couple of small problems, but learn as much as you can as quickly as you can so this guy doesn't BS you. Search the boards for dyno graphs of other stock LT1/ATI and be familiar with the curve, learn what A/F ratio it should be running (both safe and aggressive) when tuned on the dyno.
Good luck, we're looking foward to your results.
Jim
Old Jun 24, 2004 | 05:55 PM
  #43
LT1Vetteguy78's Avatar
LT1Vetteguy78
Default Re: Dyno results Pre Procharger (Hammer)
I have not been up there no, but a guy at work today who sits next to me built a 39 ford, and he told me i should go up there to the shop too...I think i might do that tommorow, i guess its a good idea....I am defenitly gonna give them a chance, i know they do good work...but he made it seem like the car was going to be in and out, if i knew it was to be this much downtime i would just did the dam stroker over the winter..He told me 1 week tops with 12 hours install time...and he told me today..they put over 30 hours already into the car.....But like i said before, he said " i'm not going to nail you for all those hours, but i'm gonna need alittle more out of you"...He is already charging me 1200 for the install and 300 for the Dyno time and tuning....<shrug>ATI claims an 8-10 hour install, but i am also getting a custom chip and Autometer gauges on the Driver Side Pillar....Right now the instal receipt says 6250 without the custom chip and auto meter and the extra hours he is charging me for.......Who knows how much this will end up costing me...i better get atleast 400rwhp outta this, else ima be pissed off
Old Jun 24, 2004 | 07:55 PM
  #44
SBNova's Avatar
SBNova
I would show up unannounced, and bring a camera. Ask what isnt fitting, and what needed custom fabrication. Have your camera visible so he knows you plan to take some pics. Maybe if he wasnt truthfull- he will change his tune. Otherwise the proof should be visible. Post the pics so we can see, Im sure someone has this can and can tell if the parts are modified or not.
Old Jun 24, 2004 | 08:29 PM
  #45
JB666's Avatar
JB666
Hmmmm... You can't say no one asked you why you wouldn't do this when your car's not being used in the winter
Seriously though, I hope it all works out.. This is giving me second thoughts on using this guy though.. If all he's done is CamAro's, that would make me a bit nervous too, it means your the Vette Guinea Pig, and I wouldn't want that position for all the Tea in China.
I feel for ya dude, this past week has been gorgeous.. Hopefully, it's all worth it, and you'll have your car BACK before the end of the summer
Old Jun 24, 2004 | 10:12 PM
  #46
LT1Vetteguy78
I actually called ATI today and spoke to a tech for awhile, he confirmed that Installing the Procharger on the LT1 is quite a job then the LT1 Camero...Like the guy doing me car, the tech said stuff about the fuel pump, air condition unit and radiator....He said its the most difficult install for their products, the LT1 Corvette engine....But he Also said...He has seen results ranging from 360rwhp on bone stock 0 mods.. to 800hp on mod'd engines....He said give the guy some time to get the install right.......I guess maybe i am being alil impatient...I hope it rains out till i get my car back
O by the way....He has done alot of Corvettes with the Procharger but they were Ls1's and L98's go figure
[Modified by LT1Vetteguy78, 9:13 PM 6/24/2004]
Old Jun 24, 2004 | 10:15 PM
  #47
JB666's Avatar
JB666
I think it'll be worth it in the end.. I'm keeping my fingers crossed for ya, since all his experience is on CamAros and this is his first Vette job.
Didn't he tell you, before he did this, that he's a Vette specialty shop and he's done lots of these?? DEFINITELY go check on your car tomorrow and make sure he's not stroking you. Remind him this ain't no CamAro.
Old Jun 24, 2004 | 10:18 PM
  #48
STL94LT1's Avatar
STL94LT1
Yeah, he is doing a custom chip and is doing a complete Dyno Tuning
If this guy claims he is doing a custom chip for your 1994 LT1. You may want to find another tuner. Because the 94 PCM doesn't use a removable chip. You have to reprogram the PCM.
At the very least, you should ask what tuning eqipment he is using.
Good Luck.
-Mike
Old Jun 25, 2004 | 12:28 AM
  #49
Bruce's Avatar
Bruce
Default Re: Dyno results Pre Procharger (STL94LT1)
Bring your car to me I will do the install for you for $500. Give one day that is all I need. First time install might take a lot times. But I had my blower in and out at countless times. It call "EXPERIENCE"
Old Jun 25, 2004 | 06:44 AM
  #50
LT1Vetteguy78
Default Re: Dyno results Pre Procharger (Bruce)
Ahh Bruce, now you tell me lol!!!!
Right, its custom reprogramming, not chip, i was using the wrong terminology
[Modified by LT1Vetteguy78, 6:12 AM 6/25/2004]
Old Jun 25, 2004 | 10:39 AM
  #51
vvv90's Avatar
vvv90
Bruce is trying to rip you off too! I'll do it for $400.
Old Jun 25, 2004 | 10:53 AM
  #52
LT1Vetteguy78
Default Re: Dyno results Pre Procharger (vvv90)
hahah, you guys are killing me :P i'll prolly end up paying 1500
Old Jun 26, 2004 | 04:25 PM
  #53
LT1Vetteguy78
Well I took a ride up to the shop today....They had my car on the lift....Its looked really good, that had it all installed...and running....they just needed to work on a few lil things...get the Autometers installed, do the Tuning, Do the reprogramming and it should be done By Wed.....There was alot of custom work they had to do they showed me everything....I'll hopefully get some pictures up on Wed....I got the Dyno Sheet hen they put my car on it...Here is what it looks like......Looks errr...i dunno you tell me.....269.6hp 297tq
If you can't make it out try this link
http://home.comcast.net/~progrmrgui/...no_Results.jpg
[Modified by LT1Vetteguy78, 3:26 PM 6/26/2004]
[Modified by LT1Vetteguy78, 3:27 PM 6/26/2004]
Old Jun 26, 2004 | 04:53 PM
  #54
Hammer's Avatar
Hammer
Default Re: Dyno results Pre Procharger (StealDads67)
Glad to see you took the ride to the shop, looking forward to your results.
Old Jun 26, 2004 | 07:01 PM
  #55
Ramanstud's Avatar
Ramanstud
judging by the dips and erratic curves (and the low #s) I would think your A/F is way off. How come they didn't show the A/F ratio on your printout???
At least it runs though.
Old Jun 26, 2004 | 11:24 PM
  #56
BowTieBlood's Avatar
BowTieBlood
Default Re: Dyno results Pre Procharger (Ramanstud)
seems like good numbers to me.... see my numbers in sig
Old Jun 27, 2004 | 02:03 AM
  #57
Ramanstud's Avatar
Ramanstud
Default Re: Dyno results Pre Procharger (BowTieBlood)
Yeah, but he has... a supercharger.
I'd think that would nab him more than a few horses if the tune was spot-on. Deep down, I'm just hoping he gets some serious numbers for all the stress of letting somebody else tinker with his baby!
EDIT: okay, apparently the posted Dyno graph is of the car PRE supercharger anyway. Kind of threw me off- I thought that was the initial run with the supercharger installed!
[Modified by Ramanstud, 4:03 PM 6/27/2004]
To Dyno results Pre Procharger
Old Jun 27, 2004 | 02:59 AM
  #58
BowTieBlood
My bad, didn't read the whole thread, just kinda glancing through, assumed that was BEFORE numbers
Old Jun 27, 2004 | 03:35 AM
  #59
LT1Vetteguy78
Yeah hehe, these are pre installation...i should have the numbers up Wed with it installed and the custom programming done.....I'll be happy with 375 at the wheels, but my expectations are 390+
Old Jun 27, 2004 | 10:21 PM
  #60
LT1Vetteguy78
What would be wrong with teh a/f ratio to make it dip lke that on the dyno sheet..and how do i get that solved,..is it a big problem? does it make a diff in the hp/tq numbers?
