hard to start when hot
- The car starts immediately when it's cold
- When it's hot and cranking, the voltage drops on the meter
- When driving around the voltage reads around 13.0 volts but drops to almost 11 when cranking
- Sometimes i will need to crank it, back off, and crank it again to fire, or just crank for a very long time
It sounds like leaky fuel injectors have hit you.
If its not doing that, and just wont fire, then it may be injector failure. Youll need to hook up a fuel pressure gauge at the rail, and shut the car off. If pressure does not hold, 1 or more is bad. And you can send them to Rich @ CruzinPerformance for cleaning, or just buy all new ones.
i did not realize this was such a common problem
yes the fuel smell is there afterwards so it's probably getting flooded
2 more questions:
1. How expensive are these to rebuild or replace?
2. Other than flooding the engine, is this doing any damage? My hobby car funds are a little low so i will probably hold out until a see a good set for sale on the forum.
Huh?
My alternator was dying slowly, and everytime I cranked her when hot, it sounded like it was bogging and wouldnt fire. In other words, it cranked and cranked, very slowly and wouldnt fire.
Replacing the alternator fixed the problem and it cranked fine from then on.
That battery died at an autocross.
I would suspect the regulator if voltage was wildly varying at cruise, not if it was steady.
I think you are right about the injector leak, but I also think the voltage regulator may be on the way out
From prior experience with other GM products.....check your coolant temp sensor to the ECM. If it has failed, then it could be telling the ECM that your engine is cold all the time, even when it is not. This causes your ECM to tell your cold start injector to provide additional fuel when cranking, which in turn floods the engine which causes the hard start when warm, but works just fine when cold. I tend to think this especially due to the fact that you smell fuel during this time.
See if you can find the leads for the cold start injector and disconnect it prior to starting when warm. If it starts as normal, then there is your problem!
Sorry I have no idea where the cold start injector is located, or actually, even if there is one on the Vette....Im still kinda new to all this..been working around those 2.8 liter engines way too long!
But, if it is there...this is just another item to check out before yanking all those injectors.
RDW
Worth checking out, IMHO.
Jake
Try starting the car when warm with your foot all the way to the floor on the accelerator. That puts the ECM into "clear flood mode' and it cuts back on the amount of fuel it lets the 8 main injectors spray. If it fires up quickly, you probably have a leaking injector or injectors.
[Modified by Mike_88Z51, 10:19 PM 6/28/2004]
Bilyk, Although I believe that the problem is due to leaking injector(s), it is a good idea to check the alternator too. These cars are very dependent on the correct level of electrical power to run properly. Trouble in the alternator area could make things worse. Most Autozone and Kragen/Checker stores will perform a free alternator/starter/battery check for you. A quick test is probably a good idea.
Frustrated,
Rich
Does this make any sense?
Ron
