95 LT1 mods... where do i begin?
Old Jun 26, 2004 | 08:18 AM
redcorvettedave's Avatar
redcorvettedave
Default Re: 95 LT1 mods... where do i begin? (93 ragtop)
Qquote:
mmmmmm, '03+ Cobras taste like chicken.
With your mod list, they couldn't be much more of a snack than a single nugget! --------------------------------------------------------------------------
want to see what a low 12sec vette looks like!!!!
Half Fast's Signature
Half Fast
1996 LT1/A4 CE Coupe
Norris Motorsports/CNC Stage III Heads, CompCam XE 224/230 .536/.544 @ 1.6 114LSA custom cam, 1.6 Pro Magnum roller rockers, GMPP LT4 HD Timing set, FMS SVO 30lb injectors, AFPR, Racetronix GSS307M fuel pump kit, LT4 knock module, 160 thermostat, Ed Wright PCM, Norris Motorsports dyno tuning, MSD Digital 6, MSD 8.5mm Super conductors, NGK TR6, K&N w/cut lid, Hooker 2151 ceramic coated headers, !cats, Corsa exhaust, Yank 3000 TC, B&M 24K GVW trans cooler, 3.45 Dana 44, HAL QA1 front shocks, Edelbrock IAS rear shocks, Powerslot rotors, EBC Greenstuff pads, Goodridge SS brake hoses, Hurst roll control, 17x11 50mm AFS Silver ZR1 rear wheels, 315/35/17 Nitto 555DR, Autometer Phantom gauges, Hella H4 lighting, 2.5lb Halotron fire extinguisher, and Passport 8500 electronic countermeasures.
NX Gemini MAF N2O system, GenX II kit, Harlan window switch, custom switch panel in console, stealth mounted 10lb bottle w/NX remote opener.
LT1 buildup featured in Corvette Fever Feb. '03 issue
1/4 : 12.12 @ 115.84 stock bottom, all motor
1/4 : 11.53 @ 121.21 + N2O
NOW THAT"S RADICAL !!!!
Old Jun 26, 2004 | 12:20 PM
DieL's Avatar
DieL
Default Re: 95 LT1 mods... where do i begin? (redcorvettedave)
heres my opinion. And this is after experiencing if first hand and watching it happen to all my friends. Nobody wants to drop large cash on a single mod. So they buy headers, and an intake, and small things etc etc... as the budget allow. Sure they will gain you power but the engine is an AIR PUMP. the biggest restrictions in a stock motor are the cam and heads. Spending money once on getting heads ported and a cam change will make a dramatic impact on performance. The stock cams in these cars are imho pathetic as theyre designed for fuel economy and smooth idles... etc etc
Old Jun 26, 2004 | 12:50 PM
redcorvettedave
QUOTE----------------------------------------------------------------------------
If you are going to add hp, ie cam, headers etc, You really need to change the diff. from the 36 series to a 44. Drag racing with hp and sticky tires will break the 36. Now IMO the best place to start is going to be a dana 44 with gears. Next is a converter, then if you want, 1.6 roller rockers, hotcam, heads reworked, headers, in that order, and exhaust is debateable if it helps or not. The LT1 exhaust is a pretty good system to begin with.
Sooner or later....the more mods you do the sooner you'll need a D44
from my first hand experience.....I put 3.54s in my D36 first...then power effects cat back....had traction problems....went to add 2600 tc found out 3.54s was frying the tranny...needed rebuilt tranny....rebuilt tranny and add shift kit and tranny cooler....after two launches on the D36 with 2600 TC..A blewn rearend!! had to put back my stock 3.07 gears back in had no more money left for D44.....my car still does decent 1/4mile times with stock 3.07s mid to low 13s...and I have spent well over 4000k..for a 13 sec vette....SO a D44 and Drag radials first... will get you closer (if not there) to a 12 sec vette( safely ) than any other route....Peace!
