intake bolt pattern
Old Jun 26, 2004 | 06:17 PM
devilfish's Avatar
devilfish
Default intake bolt pattern
is it true that my 1991 113 alu heads got the "early style intake bolt pattern" same as the Pre-1987 cylinder heads?? And therefore when I look for aftermarket heads I need to look at those with a pre-87 intake bolt pattern??
im confused
[Modified by devilfish, 12:51 AM 6/27/2004]
Old Jun 26, 2004 | 07:18 PM
devilfish's Avatar
devilfish
Default Re: intake bolt pattern (devilfish)
Old Jun 26, 2004 | 07:21 PM
Pete K's Avatar
Pete K
Your info on the bolts are accurate. I would not sweat it though. The intake bolt holes are easily elongated by you or a machinist.
Old Jun 27, 2004 | 06:43 AM
devilfish's Avatar
devilfish
Default Re: intake bolt pattern (Pete K)
Ok is there anything else that differ between heads after or before 87, like collant path etc etc?
To intake bolt pattern
