From: What did the 5 fingers say to the face? SLAP!!
Hooker 2149 and straight angle plugs
Do Hookers have any clearance issues with straight angle plug heads? I know TPIS does, so they're out. If there are clearance problems, could I just use Accel header plugs?
Re: Hooker 2149 and straight angle plugs (flyersfan1088)
The 2149 and 2151 Hooker headers are the same, base header. They both fit straight and Chevrolet angled plug heads and their clones. Check out this current thread for more info:
Re: Hooker 2149 and straight angle plugs (CFI-EFI)
Well, that thread doesn't really apply to my question. I'm not asking if they bolt to the heads, I'm asking if the spark plugs will clear. I looked at the TPIS headers on AS84's car and realized there was no way a straight angle plug would clear the primaries. I haven't seen the Hookers up close, so I didn't know if they had the same fitment issues. From the responses so far, it sounds like I need header plugs with the Hookers too. New angle plug heads aren't in the budget right now.
Try this link: http://forums.corvetteforum.com/zerothread?id=849180 When I clicked on my previous link, it brought up my reply page. My two posts on this new link addresses the plug angles the Hookers do and don't work with. By,"straight angle plug heads", are you referring to straight plug heads, vs, angled plug heads? Iron headed C4s (1984-part 1986) for which the Hookers are listed to fit have straight plugs.
RACE ON!!!
PS. I will edit my previous link. I mention this so you will know the problem was MINE, not yours.
RACE ON!!!
I have an iron headed '86. I just wanted to know if I needed to get Accel header plugs to work with the headers. I would like to order everything I need at one time, so I don't get stuck halfway through the install with having to go buy more parts I didn't know I needed. Thanks
