Good price on bending a frame back into shape?
Hope that came out right, thanks for any tips and any estimates y'all may have.
Plan on getting an estimate from a pretty good shop up here in about 1 month since I'm not currently driving my car for this month.
If you have some way out piece, assuming it is possible to repair, usually no more than 4-5 hours.
dlmeyers 90 coupe zf6 3 speed shocks
Putting things back usually moves other things around which can cause
other panels to get cracked. Plan on it..
I had that happen to a race car of mine a while back.
Now when we bend the frame I take the drivetrain out.
This may be a replace piece- or it least it was for mine after an accident and a failed repair job.
Good luck.
I don't want to say this to discourage you but I would never buy a Vette with a bent frame unless I got a really good deal. My step dad owns a body shop and has fixed lots of Vettes. He told me SMC fiber glass is the worse type of fiber glass to fix, after you fix it, a few months down the road the repaired spots seem to seep back through the paint and you can see were it was fixed.
A vettes frame is also very hard to fix, its got lots of structures in between the two main columns and the alignment will never be he same. These cars are very precise machines. I would buy a mini-van with a Bend fame, but not a Vette.
Did you find out if the frame was already realigned? it is possible that this is the best they could do.
One of my friends vette is also almost 1 inch lower on one side because of the same reason, and his frame was re-aligned the best my step dad could, and he has over 30 years of experience in body work and re-aligning frames.
Good luck!
[Modified by TheStef, 3:23 PM 6/29/2004]
I guess, hopefully they'll be able to bend it back some without screwing up something else on the car. Guess I just gotta risk it.
The shop where I plan on doing this at was recommened by another shop who works on cars for pretty much everyone I know, so I trust they're work, plus spoke to the owner of the other shop and he seems like a stand up guy.
Thanks for all the replies
As for body work, if the fiberglass errors only end up being hidden for a year or less I'm pretty sure this shop will fix it. If the repairs can make it a couple years that'll be fine, because at that point I'll be able to afford to just replace all the damaged pieces.
[Modified by BowTieBlood, 3:33 PM 6/29/2004]
