Injector size and BSFC?
Old Jun 27, 2004 | 10:20 AM
JUAN J SANCHEZ's Avatar
JUAN J SANCHEZ
Default Injector size and BSFC?
What kind of BSFC #'S are you naturally aspirated guys seeing? I'm trying to decide between a 30# or 36# injector for my 550-600HP NA motor. I have the old style DFI (for now), I'm leaning more towards the 30# but I'm curious on what results you more experienced guys may have gotten.
Old Jun 27, 2004 | 11:04 AM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In IV Veteran
Cruise-In V Veteran
Default Re: Injector size and BSFC? (JUAN J SANCHEZ)
24s here
Old Jun 27, 2004 | 12:33 PM
JUAN J SANCHEZ
Default Re: Injector size and BSFC? (CORKVETTE1)
How much power? How much fuel pressure? Thanks for the reply
Old Jun 27, 2004 | 12:41 PM
CORKVETTE1's Avatar
CORKVETTE1
Cruise-In V Veteran
600+ fwhp pressure is at 48-52 psi depending on weather conditions
Old Jun 27, 2004 | 12:55 PM
JUAN J SANCHEZ
Hopefully it works out the same for me, seems like even 30#'s would be more than enough. Seems like you have very low BSFC #'s good job. What engine management do you use? Again thanks for the reply!
Old Jun 27, 2004 | 08:11 PM
No Go's Avatar
No Go
I run 36# Accels. Duty cycle is less than 60% with stock fuel regulator and making 455 factory rating type horsepower...about 400 on a Dynojet for whp.
Leaves plenty of room to expand...
32's are also available.
Old Jun 28, 2004 | 12:46 AM
JUAN J SANCHEZ
Default Re: Injector size and BSFC? (No Go)
Thanks for the info guys!
Old Jun 28, 2004 | 01:08 AM
tjwong's Avatar
tjwong
When you get ready for an upgrade to Gen 7 let me know
Old Jun 28, 2004 | 05:32 PM
Dominic Sorresso's Avatar
Dominic Sorresso
With a BFSC of .5, the 36# will support 576hp. The 30's only 480. Given a choice I would choose the bigger injector because of duty cycle and more overhead for injector pulse width at WOT.
Old Jun 28, 2004 | 11:18 PM
JUAN J SANCHEZ
Default Re: Injector size and BSFC? (Dominic Sorresso)
I may upgrade to that Gen VII sooner than I thought. I'll get back to you on that. I'll definitly will upgrade sooner or later. I haven't purchased the injectors Yet but they will be 30 or 36#'ders. Although I would like to believe the engine will be efficient enough to work with a smaller injector. We'll see.
[Modified by JUAN J SANCHEZ, 4:20 AM 6/29/2004]
To Injector size and BSFC?
