Small-cap Dist. Conversion:
Old Jun 27, 2004 | 12:55 PM
Ramanstud's Avatar
Ramanstud
Default Small-cap Dist. Conversion:
For those that have done the coversion, did you have any compatibility issues regarding the differences in ESC modules, etc?
ChevyThunder.com states that after 1989 a different ESC module is used for the external coil distributors, so I didn't know if you guys went ahead and swapped those out or if, because the ECM is the same, it wasn't necessary?
I plan on using a proform small cap distributor, ext. coil and a conversion harness (probably from Jim's performance).
Any caveats I need to know about?
