brake feel question
Old Jun 28, 2004 | 12:08 AM
OrthoAggie's Avatar
OrthoAggie
Default brake feel question
what is everyone brake feel? is it hard the second you touch the brakes or is it a little soft and progressively gets very hard? Mine is progressivly hard and i wish it was hard on the moment i touch the brakes. It almost feels like the after i realese the brakes the calipers have enough spring in them to push fluid back up to the M/C causing more pedal travel. I was wondering if anyone has ever tried a residual pressure valve that puts a small amount of pressure keeping the fluid from flowing back to the M/C? I know they are meant to be used in a situation where the M/C is mounted below the calipers causeing fluid to flow back but this seems like a similar situation. here is one from summit which i have used before with great results and was wondering if anyone had any experience with one on a vette http://store.summitracing.com/partde...260-1874&N=120 4294922533 4294922532 305681
Old Jun 28, 2004 | 09:41 AM
OrthoAggie's Avatar
OrthoAggie
Default Re: brake feel question (deiaggie)
Old Jun 28, 2004 | 10:41 AM
VR'92's Avatar
VR'92
From: I'm the walkin dude I can see all of the world...
St. Jude Donor '03
Mine are soft anfd then they get harder. Of course its just the stock system which isn't really very good anyway. Soon I will be upgrading.
Old Jun 28, 2004 | 11:06 AM
eschoendorff's Avatar
eschoendorff
St. Jude Donor '08
Default Re: brake feel question (VictorRussell'92)
I wonder if this is normal. My pedal seems to have some play in at at the beginning of its travel. It has been like this since I bought the car. I put DOT 4 in the car and bled the brakes twice but the pedal feels the same. It goes down a little ways with almost no effort, but then you can fell the brakes come on. I am wondering if this is normal for these cars, or if I have an issue that needs attention. I would love to take it in somewhere and have it checked, but there aren't any places around here that specialize in Vettes.
Old Jun 28, 2004 | 11:23 AM
brookman's Avatar
brookman
Default Re: brake feel question (eschoendorff)
I just recently replaced my stock rubber brake hoses with braided line and my pedal went from spongy to hard. I couldn't believe the difference.
Old Jun 28, 2004 | 02:16 PM
88vettelover's Avatar
88vettelover
Default Re: brake feel question (brookman)
This is a common problem. Rubber hose deteriorate from the inside out. When this happens, you can get many problems from pedal travel to a caliper locking up.
To brake feel question
