C4...Ghost Lean?!?!?!
Old Jun 28, 2004 | 04:27 PM
boulderlt4's Avatar
boulderlt4
Default C4...Ghost Lean?!?!?!
I've got it...do you?
The passenger side of my '96 rides about .5" higher than my drivers side.
I picked her up last week at the dealership from getting her 30K mile check up. (don't ask about why a dealership). I asked them, and two guys in the service department said that it is the torsion bars under the car. That one isn't as tight as the other. I was than later told by a huge Vette guy that there is no torsion bars on this car?!?!?!
I went from the dealership to a local dyno. I than asked the shop, fairly reputable in my area, their thoughts. He said that I probably cracked my rear spring, and that is why it is riding lower on that one side. I told this to the Vette guy from above, and I thinked he pissed his pants laughing so hard.
I've heard someone in the forum say that it is the driver weight. My car barely has 24K on it and I only weigh 200 lbs, so I don't think it is from this either.
Any ideas??
:mad :mad
Old Jun 28, 2004 | 04:33 PM
TA's Avatar
TA
Default Re: C4...Ghost Lean?!?!?! (boulderlt4)
It seems that its fairly common for the pass side to be a tad higher than the left.............don't really know why. I'd get longer rear spring bolts and adjust accordingly. It'll cost you about $20 and 45 minutes of you time. Its either that or get yourself a heavy girlfriend
Old Jun 28, 2004 | 04:39 PM
boulderlt4's Avatar
boulderlt4
Default Re: C4...Ghost Lean?!?!?! (TA)
I ordered the lowering kit a few weeks ago off of Mid Amer.
I got it last week, and put it in this weekend. (Mid Amer.'s kit is complete crap BTW, both lock nuts stripped out for me. Had to go to Napa @ 7:30pm to get replacements, finding a 9/16 lock nut is not an easy task at 7pm).
I ended up finishing the job, and it looks a lot better. My only question is...from the ground to the bottom of the car, all four corners should measure the same distance..right? (Maybe the rear a little higher than the front) At least from left to right. If I lower the back right more to compensate for this lean. I will have way to much weight over the right rear, thus negatively influencing my handling ability.
If I am wrong, please let me know!
Old Jun 28, 2004 | 04:47 PM
TA's Avatar
TA
I wouldn't call myself an expert on the dynamics of handling, but I used the rear lowering kit to level out the back end and I've seen no negative effects on my car.
Old Jun 28, 2004 | 04:49 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
You didn't adjust those nuts with the weight of the car on them, did you??
They should only be turned with the weight off the suspension.
Lowering a corner takes weight OFF that wheel/tire.
Larry
Old Jun 28, 2004 | 05:10 PM
Wheelman's Avatar
Wheelman
No torsion bars on your c4. Stupid dealer
Old Jun 28, 2004 | 05:16 PM
boulderlt4's Avatar
boulderlt4
Default Re: C4...Ghost Lean?!?!?! (code5coupe)
No. The the teflon (or whatever the hell it is) inserts stripped out while putting the nuts on initially. While everything was jacked up!!! I'm sitting there tightening the nuts, and all of a suddened I feel the nut break loose. I take out the wrench and sure enough, just below the nut, on the bolt, is that damn insert! I still need to call Mid. Amer. on this one!!
Old Jun 28, 2004 | 06:36 PM
85vet's Avatar
85vet
Cruise-In V Veteran
Were you using a bottle jack to lift the spring up to take tension off of the nut?
I change my spring tension every time I change tires - Drags vs street. Allways use jack to take the tension off of spring with no problems.
Old Jun 28, 2004 | 06:44 PM
boulderlt4's Avatar
boulderlt4
Default Re: C4...Ghost Lean?!?!?! (85vet)
Had to borrow my buddies floorjack. Had mine to lift the car, and his to lift the spring.
There was no tension on the nut, or the bolt, when the POS stripped!
Old Jun 29, 2004 | 09:50 AM
rocco16's Avatar
rocco16
So, the nut threads didn't strip, the nylon locking insert failed.
Yeah, bad batch of locknuts...call MAM.
Larry
To C4...Ghost Lean?!?!?!
