Oil question
Old Jun 28, 2004 | 08:51 PM
ir0nmaiden420's Avatar
ir0nmaiden420
From: Sarcasm. Just one of the many services I offer.
Default Oil question
Is is possible to tell if you are low on oil by the oil pressure/temperature reading?
Old Jun 28, 2004 | 08:59 PM
Black87c4's Avatar
Black87c4
Default Re: Oil question (ir0nmaiden420)
I'd probably say if you use the oil pressure method to determine if your low on oil your peforming a rebuild shortly after, checking the dipstick just might be a little easier.
Old Jun 28, 2004 | 10:38 PM
vader86's Avatar
vader86
Usually only if youre REALLY low, from pressure.
Old Jun 28, 2004 | 11:53 PM
JAKE's Avatar
JAKE
Default Re: Oil question (vader86)
If it's low enough to show up on the gauge, the pump will b e intermittently sucking air and oil because the pickup is being uncovered. when it sucks air, the pressure will drop and your bearings (among other things) are being starved.
Jake
Old Jun 29, 2004 | 09:42 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Default Re: Oil question (Black87c4)
I love it!!
..and I agree wholeheartedly.
Larry
To Oil question
