[1985] Total Electrical Failure
Old Jul 3, 2004 | 08:33 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default [1985] Total Electrical Failure
I went out to start my 1985 tonight and no joy - engine doesn't turn over at all, no lights come on. So, I figure that the battery has died and get out my battery charger. Battery charger refuses to work - in fact it sees no battery to charge between the positive terminal and the engine ground. Battery charger is known good...any ideas?
Old Jul 3, 2004 | 08:42 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Default Re: [1985] Total Electrical Failure (j3studio)
Try hooking both cables direct to the battery terminals. If that works, you may have bad battery connections. If that doesn't work, disconnect both cables and place the charger across the battery terminals and see if the battery charges. You may have a bad battery or something is draining it.
[Modified by Hooked on Vettes, 8:45 PM 7/3/2004]
Old Jul 3, 2004 | 08:46 PM
bogus's Avatar
bogus
I am betting on a shorted cell in the battery...
Remove the terminals and test the battery.
Old Jul 3, 2004 | 09:45 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Thanks Hooked and Andy - some stuff to try in the morning...
Old Jul 3, 2004 | 09:59 PM
Bilyk's Avatar
Bilyk
sounds like a bad terminal connection
if everything is wired tight, i would guess a dead cell
i had both problems happen to me
Old Jul 4, 2004 | 12:26 AM
jfb's Avatar
jfb
Your battery is open circuit. You may have a corroded battery cable lug or you may have an internal cell connector broken. Remove the cables (neg first) and clean the lugs and the battery terminals and before you reconnect, clip your battery charger onto the battery terminals. If it will not show any charging current your battery is open circuit and needs replacing. When reconnecting the cables, connect the neg last.
Old Jul 4, 2004 | 08:47 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
It was the battery - time to see what kind of warranty AC Delco has on a three month old product that had been used for less than a 1000 miles...
..thanks to all who responded on a holiday weekend!
:flag
[Modified by j3studio, 8:48 PM 7/4/2004]
Old Jul 4, 2004 | 10:41 PM
Bilyk's Avatar
Bilyk
delco batteries are replaced for free in the first year if they fail (assuming their warranty is the same worldwide)
Old Jul 5, 2004 | 06:09 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Re: [1985] Total Electrical Failure (Bilyk)
Thanks! One more (clueless) question related to this issue...if the multimeter I just purchased shows infinite resistance does this confirm the deadcell diagnosis?
Old Jul 5, 2004 | 06:56 PM
bogus's Avatar
bogus
yup.
Old Jul 5, 2004 | 08:15 PM
j3studio's Avatar
j3studio
Cruise-In V Veteran
St. Jude Donor '06
Default Re: [1985] Total Electrical Failure (bogus)
Thanks, Andy - I was so good at this...um...15 years ago.
By the way, how are you doing?
To [1985] Total Electrical Failure
