From: What did the 5 fingers say to the face? SLAP!!
Hooker 2149 fitment problem
I got the drivers side on earlier this evening and ran into a problem. The flange where the Y-pipe connects is touching the floor of the car. It actually scuffed the floorpan when the header was snugged tight. Has anyone else run into this problem? Thanks
I got a large prybar and made some room....its real tight there, you will feel heat and vibration in the floor. Thats why I made it work with the shield on.
I installed Hedman hedders on mine. I experienced absolutely no fitment issues whatsoever. Earlier this evening I went to snug up the hedder bolts and they were all still tight. I don't see why Hedman get such a bad wrap on this forum and Hookers get all the praise.
I removed the metal heat shield. cut a hole in the fibreglass an fixed a metal soup bowl type thing inside the footwell to cover the hole, This gave me about 1/2 " clearance. (I actually used an end cover from an old electrical transformer)
With the carpet back in place it is undetectable, no problems.
