dumb newbie question
Old Jul 4, 2004 | 02:07 PM
1996man's Avatar
1996man
Default dumb newbie question
please be patient with me but what all needs to be monitered when running nitrous? are you guys running A pillar guages? bottle temp? pressure? ect? these are just guesses. im just trying to do my homework on the subject?
Old Jul 4, 2004 | 02:46 PM
krivera's Avatar
krivera
Default Re: dumb newbie question (1996man)
With nitrous it depends on what size of shot you are running? For example if you are running a 100 shot you can run it on a stock car! but when you start running 200 shot foggers and such you must have many different things to make sure you do not blow the motor up...
Stock: pressure gauge, fuel cut off switch and Bottle warmer to keep pressure consistant.
More then Stock: Bottle warmer, pressure gauge, Fuel cut off, progressive box or similiar, bigger injectors, custom PC Tune, Nitrous cam...depends what you want.
But i always suggest bigger fuel pump and injectors when running the bottle.
Old Jul 4, 2004 | 08:03 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: dumb newbie question (krivera)
I run a Jacob's Nitrous Mastermind, and it keeps an eye on fuel pressure, and it also shuts off the nitrous before it rev limits. I can also use it to retard timing, start the nitrous at a designated rpm and have progressive control as well. Other than what was stated above, I like wet kits and a good working ignition or some kind of spark amplifier. Don't forget to get that spark gap down to about .035 or so. Good luck and I commend you on doing your homework first.
To dumb newbie question
