Beam Plate Alternative?
All it would take would be a flat piece of metal and some nuts of the correct size, drill some holes and weld.
They actually do what they say they do - they control the torsonal load of power application. Stops the rear wheel from kicking out.
I have them, and would get them again.
Front Holes = 1.775 Center line with a .510 hole diameter,
hex head across flats = .710”
Rear Holes = 1.460 Center line with a .590 hole diameter, hex head across flats = .820”
I would take a piece of 1.375 or 1.5" wide X .50" thick CRS and machine a .25 deep slot down the middle for the nut flats, and then slot the middle for the clearance hole, same way,
No welding required and the nuts could drop into the slot.
I still can't see how these beam plates would strengthen anything. Can someone explain this to me.....Its a small plate that is sitting on the C-beam. If any flex at all is going to happen, its going to be the c-beam itself, with or without the plates.
I can see how installing the bolts would be easier, but I have done it so many times its a 2 minute ordeal. I did bullet nose the bolts a little to make getting them up through a little easier.
But I call BS on the plates making the car more rigid. Its like putting a patch on a pair of your jean, and saying the entire pant leg is stiffer now. It might be stronger in that one little area, but all the flexing is going to take place in the middle anyways.
http://www.zfdoc.com/c4beamplate.htm
BTW, my car does kick out to the right.
But I picked up an 1/8" piece of scrap steel out of the garage and two metal nuts. Welded them on three sides each and took a hammer to the plate to flatten it back out (I'm not a great welder).
All in all, $2.00 for the grade 8 stainless nuts and about 20 minutes of fab work. I don't know what the specs are, as I just used the C-beam as a template since it was down. The bolts threaded right up (after all, when you install a bolt you tend to turn the bolt and keep the nut stationary) and no problems. I wouldn't do the job without a similar device!
The torque to the beam is going to deflect the middle point of the beam. These clamps are merely on the end, where its already at its stiffest point. They do NOTHING for the center of the beam. Therefore if there is going to be flex, then its going to flex with or without them.
Take a straw, hold it at either end and twist the two ends in either direction. The straw will twist in the middle, not at the ends. That is because the ends are already held and strongest and the torque will transfer to the weakest point, or least supported point, which is the midway between the supports.
Granted a straw is different from the C-beam, but the scenerio of what will happen is the same.
These I am sure are nice for putting the bolts back up through and I give the guy credit for putting the time and effort forth to make them. But I would not buy for a second they make the car stiffer.
Ol'RJ made me a set so I can at least try them!
Keep updating us on your runs!
I think you are 100% on the money. I just installed the Beam Plates last week. I can tell you that I do not feel any difference with them. Thank god I had them though cause I was not looking foward to putting that C beam back in without em! Like I said maybe you need a monster of a car to feel the difference but my ol ride is just the same which isn't a bad thing!
I didn't notice a difference either, and really wasn't expecting one for the reasons ski pointed out. These differences may or may not be more apparent on a heavily modified car I really dunno. The only reason I bought them was to make C-beam installation easier. It was fairly difficult and slightly bloody getting my big hands with big tools to the top of the beam for removal.
Re-installation was a breeze with the plates.
