AFPR: How much fuel pressure should I be running?
131,000 on stock motor with valve covers never been removed
unless otherwise stated all components are stock (in other words for example....my injectors are stock so figure the 131,000 figure for stock stuff)
MODS as follows:
Open Air lid with K&N Filter & custom air inlets allowing more air (semi-ram air)
Relocated MAT Sensor
2 1/2 rear Dynamax Y-Pipe with crossover tube
Mid America Targa stainless steel mufflers (basically tubes with mini glass packs in them) I definitely noticed a difference in HP and torque (moved the torque into the midband range)
High-Flow Dynamax Cat. Converter
New O2 sensor
Mobil 1 oil
160 thermostat with Throttlebody Bypass
Airfoil and Adjusted to .65 Throttlebody Position Sensor
No Frisbee
Craig Marcho Chip allowing early fan turn on (185 and 195)
pretty much it....from what you can see....the mod list is mostly free stuff and the air and exhaust has been messed with a bit....so what should I be running for fuel pressure....keep it stock? Right now Iam at like 2lbs over stock....40 to be exact...I checked and stock was 38.5
Just trying to squeeze out everybit of a HP I can get...lol.....arn't we all? hehe
thanks all
jeff
I would suggest around 45-46psi with your mods, with the vacuum line off at idle.
