Shifter Knob Replacement
Old Jul 6, 2004 | 09:55 PM
JAMixon's Avatar
JAMixon
4th Gear
Default Shifter **** Replacement
Hello all...Avid forum reader here, just never posted a new topic...until now
Perhaps I'm overlooking the obvious, but how is the shifter **** removed? I'm in the process of trying to replace a worn **** and boot and have been struggling with it for way too long!
Thanks for the help!
Old Jul 6, 2004 | 10:01 PM
Strick's Avatar
Strick
Default Re: Shifter **** Replacement (JAMixon)
What year? Auto or stick?
Old Jul 6, 2004 | 10:04 PM
JAMixon's Avatar
JAMixon
4th Gear
Sorry - This is an 85, auto.
Old Jul 6, 2004 | 10:12 PM
Strick's Avatar
Strick
I can't help you, as I have a 92 6 speed **** right in front of me. Someone will jump in soon. See ya.
Old Jul 6, 2004 | 10:19 PM
CowboyNVette's Avatar
CowboyNVette
Default Re: Shifter **** Replacement (Strick)
Wish I could help too but I've got a 6 speed also.
Old Jul 6, 2004 | 10:21 PM
Steel Blue 91's Avatar
Steel Blue 91
Should be the same as my 91. Move the shifter to neutral. Use a small flat blade screwdriver tp pry the button out. You'll see a ring holding the **** on the shaft. Use a pair of snap ring pliers to remove the ring. Note: hold your hand over the **** when removing the snap ring. This will prevent the snap ring from flying off to God knows where. Pull up sharply on the **** and it should pop off. If not, it might need a little persuasion.
Old Jul 6, 2004 | 10:22 PM
LD85's Avatar
LD85
Default Re: Shifter **** Replacement (CowboyNVette)
Took mine off tonight.
1. Pull the flat cap
2. Pull the steel key way pin
3. Unscrew the little OD "T" part
4. Remove
Old Jul 6, 2004 | 10:23 PM
LD85's Avatar
LD85
Default Re: Shifter **** Replacement (ld85)
Oh yeah, this is what I replaced it with
Old Jul 6, 2004 | 10:32 PM
JAMixon's Avatar
JAMixon
4th Gear
THE BEST FORUM ON THE NET!
Thanks for the posts!! I'll be in the garage popping that button off tomorrow and replacing that 20 year old **** and boot.
Those are the answers I needed. The Forum always comes through
Thanks again!
To Shifter Knob Replacement
