here is a dum question
Old Jul 7, 2004 | 10:25 AM
1fastvett's Avatar
1fastvett
Default here is a dum question
can i change the belt on my 86 procharged,intercooled,stoked motor to a chain insted.change all pully to gears.so i stop throwing the belt?
Old Jul 7, 2004 | 10:35 AM
85blkZ51's Avatar
85blkZ51
Default Re: here is a dum question (1fastvett)
Is the alignment of the pullys correct? Thats another dumb question, but "When in Rome...."
Old Jul 7, 2004 | 10:36 AM
jp2002ls1's Avatar
jp2002ls1
I would stick with the belt, a chain could cause much damage. Check to see if all your pulleys are lined up perfectly straight, it is common when throwing a belt all the time that the pulleys aren't alligned correctly or one of them is bent. You could also make a cover over the blower pulley to keep it on.
Old Jul 7, 2004 | 10:54 AM
h rocks's Avatar
h rocks
Check out that blower Forum, your problem is NOT unique.
To here is a dum question
