Intake Manifold
Old Jul 7, 2004 | 02:51 PM
88421VETTE's Avatar
88421VETTE
Default Intake Manifold
Will an intake manifold off an 88 GTA fit on my l98 engine out of a 88 Corvette if not tell me what I need to do. Thanks
Old Jul 7, 2004 | 02:54 PM
Black87c4's Avatar
Black87c4
Default Re: Intake Manifold (88421VETTE)
Will fit
Old Jul 7, 2004 | 03:55 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I believe the F-body L98 with iron heads used internal EGR whereas your Al headed L98 uses external EGR.
Check that the F-body intake has facility for external EGR.
You might also check out the bolt hole angles as they changed on the F-body.
Old Jul 7, 2004 | 04:24 PM
ANTI VENOM's Avatar
ANTI VENOM
Default Re: Intake Manifold (65Z01)
The trans am may have the ninth injector in there also. I don't know if yours does or not. If your's does, and that one doesn't, then you need to make changes. Good luck!
Old Jul 7, 2004 | 05:20 PM
65Z01's Avatar
65Z01
Default Re: Intake Manifold (ANTI VENOM)
Both '88 L98s have the cold start injector.
Old Jul 8, 2004 | 12:03 PM
6SSPD's Avatar
6SSPD
Remember that the F-BODY and Y-BODY intakes use different bolt angles for the (2) center intake bolt holes. The F-BODY uses a 73 degree angle, where as the Y-BODY intake uses conventional 90 bolt angles for all (12) bolt holes. HTH's
Old Jul 8, 2004 | 05:06 PM
Roadster89's Avatar
Roadster89
You will also need to change the fuel rails... Gas feed from Passenger side on Vett, Driver's side on F Body
Old Jul 8, 2004 | 05:09 PM
NUckINg FuTS's Avatar
NUckINg FuTS
I believe you will also need to drill a hole for the heater hose fitting near the distributor.
To Intake Manifold
