Several Necessary Questions
Old Jul 8, 2004 | 09:47 PM
1986coupe's Avatar
1986coupe
Default Several Necessary Questions
My 1986 Vette is not running as well as it should. If I set the timing it runs fine until I reconnec the EST cable. Then the ECM take over and the idle tends to be around 1000RPM. This seems a little high.
My latest theory is that the Electronic Air Contidioning (new for 1986) is causing the ECM to think that the compressor is on when it really isn't. Does anyone have experience with this?
Next, if the above isn't the problem and I am not getting any serious error codes then how do I test to see if the ECM is bad?
Old Jul 8, 2004 | 09:51 PM
vader86's Avatar
vader86
You need to check the TPS voltage, probably also need to remove the TB and then clean the IAC valve. Both contribute to the idle directly.
Old Jul 8, 2004 | 10:03 PM
moteman1's Avatar
moteman1
Check out www.C4vettes.com as this will help you dial in to seeking the codes for your car. This site also covers many other pieces of information re: C4's
Good luck.
To Several Necessary Questions
