Injector pricing
Old Jul 10, 2004 | 10:44 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
Default Injector pricing
May have to buy new injectors. Just curious, found a site that is selling brand new GM/Bosch 25lb/hr @3bar for $99.00 +$ 11.95 s&h.
I. is this a decent price (price is for all 8 injectors)
2. are these injectors ok to use in a stock `87.
they are not flow matched.
Ken :flag
Old Jul 10, 2004 | 10:50 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Old Jul 10, 2004 | 10:53 PM
chriswtx's Avatar
chriswtx
That sounds way too cheap. Are you sure that is for all 8? If they say it is somthing fishy is going on...
Old Jul 10, 2004 | 10:56 PM
kenv's Avatar
kenv
St. Jude Donor '10
Yep for all 8 it says while they last. I don`t know if we are allowed to talk about other sale sites if they are not listed on the vendors area on the left.
Ken :flag
Old Jul 11, 2004 | 02:38 AM
tjwong's Avatar
tjwong
I think you are refering the bosch LS1 take out units from SLP. If that is so, then those injectors will work fine in your car. They are rated at 28 lb at 400kPA rail pressures, at 400kPA which is what yours is, they will be derated to about 25 lb/hr. Your 87 will run but will run on the rich side. Because your original injectors were rated at either 19 or 22 lb/hr, the worse case scenario is that you would have to have a chip burned for the new injectors.
Old Jul 11, 2004 | 11:07 AM
kenv's Avatar
kenv
St. Jude Donor '10
Thanks; that is exactly the advice I was looking for
It sounds like a great deal for the injectors. I`ll be ordering them in 5 mins.
Ken :flag
Old Jul 11, 2004 | 10:26 PM
mikey whipreck's Avatar
mikey whipreck
Default Bosch injectors
The local autozone had a set of Bosch injectors for my '85, price was $84.99. I've always though Bosch was a good name, anyone use these?
Old Jul 11, 2004 | 11:25 PM
korvette4u's Avatar
korvette4u
what were the parts number for these injector u talk about?
i on that site now and can not seem to find bosch
Old Jul 12, 2004 | 01:04 PM
mikey whipreck
haven't checked the website yet... i'm on my way there now, but the part number is: 0280150223. The guy at the counter told me this was a set of 8 injectors and all the seals i would need. I guess i'll go to the website now and find out if he was lying or not.
Old Jul 12, 2004 | 01:18 PM
mikey whipreck
...just back from the website and the part numbers dont match up... maybe you could try a store with that part number? i dont' know why their different.
Old Jul 12, 2004 | 04:12 PM
USAsOnlyWay
Uhh, I just called SLP.
They say those 35;b/hrs are a no go.
They won't fit I geuss?
(too loose)
Old Jul 12, 2004 | 07:29 PM
JackDidley's Avatar
JackDidley
I have those injectors from SLP in my 87. Nice parts but my car is way too rich at low rpm. I have a ski chip and its still rich. I just sent it back to him so he can lean it out. I think these flow more than SLP says or ski would have gotten the chip a lot closer the first time. Just my .02
Old Jul 12, 2004 | 10:20 PM
kenv's Avatar
kenv
St. Jude Donor '10
I just checked the Autozone web site, & the only injectors I found were MSDs at $64ea
Ken
Old Jul 12, 2004 | 11:09 PM
mikey whipreck
yeah... i went to their website- the item number doesn't match up
just go to your local autozone, see what they have
Old Jul 13, 2004 | 05:29 PM
joseph p's Avatar
joseph p
In case you're interested...I thought I neede injectors because my '89 L98 wouldn't start instantly if it sat overnight. Bought new ones, problem was still there. Wound up that a "kill switch" the former owner had installed was going bad. When it finally quit and I removed the switch, the car started perfect everytime. Lesson learned, injectors were fine. If you're interested you can have the injectors I took out for $50 plus shipping.
Old Jul 13, 2004 | 07:39 PM
USAsOnlyWay
I'll take em if possible!
Depending on what they are and if that offer is directed to me of course.
Old Jul 13, 2004 | 08:08 PM
kenv's Avatar
kenv
St. Jude Donor '10
(too loose)
I called SLP about the injectors today. Their engineer has them in his l98 `88 Trans Am. He said they fit a little loose (up & down), but that they are no problem & will not leak. He said they will work fine. we`ll see. I kept my order in
Ken :flag
To Injector pricing
Old Jul 14, 2004 | 12:19 PM
USAsOnlyWay
What is going on with SLP.!!!
Ughh...I will call back today...thanks!
Old Jul 14, 2004 | 09:14 PM
kenv's Avatar
kenv
St. Jude Donor '10
Boy they have fast delivery! They came today . I don`t know how they will work, but they look brand new & do not smell like gas or anything, so I don`t think they are used take-offs (could be though)
they even have -O- rings on them.
Ken. :flag
Old Jul 16, 2004 | 10:36 PM
USAsOnlyWay
Yeah, I called em again and after talking to Tom (tjwong) too I went with em. Now they aren't pink like Agent86's are they!! :
