Swapping wheels
Old Jul 11, 2004 | 09:45 AM
jcs44's Avatar
jcs44
Default Swapping wheels
I have a 96 LT4 with stock sawblades with the low tire pressure warning system and Gooodyear run flats installed. I've just purchased some AFS ZR-1 style wheels and I want to swap the tires over to the new wheels. I'm told that I must also put the tire pressure sensors in the new wheels to avoid having a warning light on all the time for low tire pressure. Is there a way to disable that warning light so I don't have to remove the sensores from the sawblades?
Thanks, JCS44
96 LT4, Vert, Blk/Blk
Old Jul 12, 2004 | 08:32 AM
rodj's Avatar
rodj
Could always remove the bulb from display. Don't know if it brings up any codes though.
Old Jul 12, 2004 | 09:08 AM
STEVEN13's Avatar
STEVEN13
Removing the bulb will not set any codes as this system is independent. I removed mine 2 years ago with no problem.
Steven
To Swapping wheels
