94 vibration at specific speeds
Old Jul 11, 2004 | 09:30 PM
lewbar's Avatar
lewbar
4th Gear
Default 94 vibration at specific speeds
Hi....hope I can explain this problem and have it make sense, and someone can give me some ideas.
94 LT1 A/T. Had the tires balanced, 4 wheel alignment etc and all seemed fine from the mechanics point of view. After a few hundred miles I was getting a vibration through the steering wheel and the seat of my pants at speeds of 40-42 and again in the mid 70's. Had the tires rebalanced, an alignment again but it did not correct the problem. Total transmission flush/check at 30k, the car now has 45k. Now I could go to a mechanic in my area (small rural area) and go through a very expensive process of elimination as they replace piece by piece till they find the problem, but there are more intelligent people on this board than I could find locally. Tires are in very good condition (5k) brakes about the same. I'm thinking U joints but don't really know how to check them. Transmission shift fine, running condition is great. Any thoughts on this? Any help would be greatly appreciated.
Don
Old Jul 11, 2004 | 10:33 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
It could be a driveline vibration but from out of balance, not u-joints I don't think. They can come and go at certain speeds too but I'd still have the tires checked again. Those speeds really lean toward a balance or other tire problem. Don't spend any more on alignments, it will neither cause nor cure a vibration.
Old Jul 11, 2004 | 10:41 PM
vader86's Avatar
vader86
It could be the balljoints, thats usually what it is if not the tire balancing.
I remember one other thing in the driveline that people were replacing that fixed it, it wasnt the U-joints though, I just cant remember what it was, and the search isnt working completely.
Old Jul 11, 2004 | 11:01 PM
BigTodd's Avatar
BigTodd
I had a simular problem on my 93, found out my bolts connecting my flywheel to the torque converter were loose. I tightened them to specs and the problem was gone.
Old Jul 12, 2004 | 04:26 AM
VenkmanP's Avatar
VenkmanP
Was the balancing done on a Hunter road force machine? If not get it done on one.
Old Jul 12, 2004 | 08:42 AM
lewbar's Avatar
lewbar
4th Gear
Thanks for the info.....I do appreciate it
don
To 94 vibration at specific speeds
