Code 33 !!! 1988, Need help from the pro's
Old Aug 24, 2004 | 05:32 PM
TheStef's Avatar
TheStef
Send me your email address, and I'll send it to you
Old Aug 25, 2004 | 05:43 AM
884fun's Avatar
884fun
Originally Posted by DKOV
1990 and nope... notta
I have the butterflies, the accordian tube and then the K&N FIPK. That's it.
Scott----------
Man someone pinched your MAF!
Old Oct 6, 2013 | 04:10 PM
Hackett77's Avatar
Hackett77
7th Gear
Originally Posted by TrueBlue ChevyDude
I had trhis same problem on my 88, went through all the logic charts, pulled my hair out, no solution...
What finally solved theproblem was playing around with the TPS setting. I had it smack dab in the middle of the suggested range (.54 I think), and it had the exact same symptoms that you describe. I had minor intake modifications and true dual long tube header exhaust.
I reset the TPS down to thebottom end of the acceptable range (.48 or so) and VOILA! no more problems.
I guess at .54 volts closed throttle the math just didn't add up for the computer. It figured that there should be more airflow than there actually was for .54 volts. Changed it to .48, and ran like the wind. I made sure that at full throttle the TPS was still reporting full throttle, and it was, read over 4 volts.... alls well
I have a 1988 vette with the code 33 and this person nailed it for me, previous owners replace the MAF sensor, Relays and rebuilt the throttle body with no luck. I was dreading the Possibility of an ECM, but hooked up scanner and my TPS was at 6.4v on closed throttle. Thanks TrueBlue ChevyDude
Old Oct 6, 2013 | 11:18 PM
Cliff Harris's Avatar
Cliff Harris
You can get a code 33 if the connection between the MAF and the ECM is open.
Could be corroded contacts in the connector, broken wire or no power getting to the MAF (MAF power relay).
Old Oct 8, 2013 | 10:41 AM
tunedport85inject's Avatar
tunedport85inject
This is a 9 year old thread...
