I fixed the leak finally
Old Jul 13, 2004 | 12:21 AM
calebchoson's Avatar
calebchoson
Default I fixed the leak finally
Seems that all I needed was an oil breather. I have only driving it a couple times today but i have seen no oil leaking on the exhaust.
Old Jul 13, 2004 | 01:45 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Congrats, I've found oil leaks to be very frustrating.
Old Jul 13, 2004 | 02:36 AM
calebchoson
yes they are. Now i need to find the problem with my performance.Im thinking i may need a new tps and iac.
Old Jul 13, 2004 | 06:59 AM
rons85's Avatar
rons85
An oil breather - do you mean something additional to the factory vent systems? If so, then something isn't or wasn't working the way it should. If the PCV valve was actually Working no external vent would be necessary - it would actually be bad in that it would just create a big vacuum leak through the PCV circuit!
To I fixed the leak finally
