Gutting your converter
Old Jul 16, 2004 | 05:22 AM
avtt94's Avatar
avtt94
Default Gutting your converter
I have a 94 Vette and was wondering if you get much power from gutting your converters?Also how do you keep a code from going off when you gut the converter?One more question,when my gas gauge gets to about 1/4 of a tank and I get on the car hard it tries to die out like its not getting enough gas.Anyone know what causes this.
Old Jul 16, 2004 | 08:37 AM
rodj's Avatar
rodj
There are no baffles in the tank so whenthe level gets down the fuel sloshes away from the pump under hard accel or cornering and it runs out of gas.GM could have done better on a performance car.
Old Jul 16, 2004 | 09:19 AM
rick lambert's Avatar
rick lambert
I think most everyone would agree that by gutting the cats you'll see quite an increase in performance, especially if there's any restriction now. If the engines running good I don't think you'll throw any codes just by gutting the cats.
Old Jul 16, 2004 | 11:39 AM
redcorvettedave's Avatar
redcorvettedave
I took out my &#@ and straight pipe to resonator ...cut behind upper 02 bung.. weld pipe back to resonator just use the front 02 sensors on both sides don't need the rear 02 0n a 94lt1 ...no codes....
man them @#& are heavy
Old Jul 16, 2004 | 12:32 PM
Wildcat1's Avatar
Wildcat1
It won't throw any codes on a 94 model. However, I would recommend taking them all the way off. I've had a 84 and a 91 that were gutted and it made the resonance rediculous. My 94 isn't near as bad with them completely gone.
I'm wondering about the resonator myself. I've heard it was heavy, but I'm scared to take it off for the same reason listed above about the gutted kitties.
Old Jul 16, 2004 | 08:38 PM
Brimis's Avatar
Brimis
I gutted my cat and also have no codes.
To Gutting your converter
