A/C line freezing!!
Old Jul 16, 2004 | 11:21 PM
828790vetteman's Avatar
828790vetteman
Default A/C line freezing!!
I recently converted my R12 System to R134a and it seems to be cooling great. I have checked the vent temperatures with a thermometer and the coolest temperature I have gotten was around 44-45 degrees. I am confused though because the line coming from the evaporator to the accumulator is forming ice on it. Is this supposed to happen?
Thanks for any advice!
Old Jul 16, 2004 | 11:37 PM
828790vetteman
Sorry I forgot to say this is for my 1990 Corvette.
Old Jul 17, 2004 | 01:13 PM
SunCr's Avatar
SunCr
NO - cutoff pressure is too low or there is a restriction on the suction side. Set cutoff threshold to 22.5 psi by turning the screw between the terminals clockwise to increase it. If that doesn't fix it, it's restricted - did you replace the accumulator? Or you've mixed R134 with R12.
Old Jul 17, 2004 | 01:53 PM
kenv's Avatar
kenv
From: levittown pa. usa Even a bad day with my `Vette, is better than a good day at work
St. Jude Donor '10
My older chevy used to have frost on the lines when it was low on freon.
Old Jul 18, 2004 | 04:22 PM
Jloshotz's Avatar
Jloshotz
Low fan speed or restricted airflow will cause this symptom as well..
To A/C line freezing!!
