LS1 Injectors on a LT1
Old Jul 17, 2004 | 12:51 PM
yellowlust's Avatar
yellowlust
Default LS1 Injectors on a LT1
LT1s are 22lbs (?)
LS1s are ?
Is it worth doing or too rich?
Old Jul 17, 2004 | 04:04 PM
Switch's Avatar
Switch
Since the flow a bit more and opening/closing times are different the PCM values will need to be changed.
I'm running a set in my 95
Gordon
Old Jul 17, 2004 | 05:42 PM
Zix's Avatar
Zix
Originally Posted by yellowlust
LT1s are 22lbs (?)
LS1s are ?
LS1 injectors are 28.8@52 if I remember right. They don't flow much more than the stock LT injectors with the stock fuel pressure of an LT1 car.
Old Jul 17, 2004 | 07:57 PM
yellowlust's Avatar
yellowlust
If someone were to give me a set would they be worth using? Or would the cost of reprogramming the PCM outweigh the cost of refurbing mine? (~$100)
Old Jul 17, 2004 | 08:22 PM
Zix's Avatar
Zix
Well, you may need a reprogram as well as an adjustable fuel pressure regulator, I don't know what the LS injectors flow at the stock 40-42Lbs that an LT1 runs at. If they are clost to stock you might be able to get away with it. I know there are plenty of people that run them so it can't be that bad.
Old Jul 17, 2004 | 08:29 PM
tjwong's Avatar
tjwong
The LS1 injectors are rated at 28lbs/hr and at the fuel rail pressure of a 93/96 LT1/LT4 engine which is 43 PSI those same injectors would flow about 25lb/hr.
If you have a 94 and up LT1 the flow rate for your injectors are 24lb/hr, if you own a LT4 then those injectors are rated at appr. 28lb/hr, the earlier 92/93 LT1s had 22lb/hr inejectors.
At a cost of $99 from SLP those are a real good injectors if you need some. I see that you are in Portland Oregon, just as I am for a simple reflash and injector size change I would only charge you $50 if you bring the PCM to me Total cost about $150 not including shipping on your new injectors. You can't buy two GM replacements from a dealer for that!
To LS1 Injectors on a LT1
