Rusty Hood Latch
Old Jul 17, 2004 | 05:18 PM
PMARTINEZ92126's Avatar
PMARTINEZ92126
Default Rusty Hood Latch
I have an 86 corvette and where the hood closes on the drivers side I have noticed rust. It's in where the hood spring goes down and latches. I know I have to go in there and clean that rust out before it causes a problem. How can I pop that plate cover off so I can remove the rust.
Old Jul 17, 2004 | 06:20 PM
70ZZ3 96LT4's Avatar
70ZZ3 96LT4
Default Hinge Rust
Not at home to look at my car until later, but I believe your rust problem has occured because the water drain holes at the bottom of the latch are clogged. This is a problem area for the C4's.
