Changing Injectors with a SR
Old Jul 19, 2004 | 11:17 AM
vette_tweak's Avatar
vette_tweak
Default Changing Injectors with a SR
Has anyone with a SuperRam changed their injectors without removing the plenum or runners of the SR?
Old Jul 19, 2004 | 11:20 AM
scorp508's Avatar
scorp508
Originally Posted by vette_tweak
Has anyone with a SuperRam changed their injectors with removing the plenum or runners of the SR?
I'll guess that you mean "without" removing the plenum or runners. It cannot be done. You have to remove the plenum, but the runners can stay on. Remove the plenum and then remove the 4 (I think 4) screws that hold the fuel rails together as a unit. You can then pop each rail out on its own and change the injectors. Put the rails back in and refasten the crossovers.
Don't forget to get new o-rings for the rails when you do this. If you don't at least make sure you put motor oil on the o-rings for reassembly otherwise leaks are prone as the o-rings don't seat right without some lube.
Old Jul 19, 2004 | 12:26 PM
vette_tweak
yes I meant "without"...Thanks Scorp...
To Changing Injectors with a SR
