Antenna on a 1986
Old Jul 19, 2004 | 09:30 PM
wirenut3's Avatar
wirenut3
Default Antenna on a 1986
Hi just want to know what kind of a job is it to change a power antenna mine keeps running Thanks.
Old Jul 19, 2004 | 09:40 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
It's an easy job. Disconnect the relay connection under trim, beside hatch latch. Also the coaxial connection behind drivers side cargo shade track. Its under the carpet behind the track. Pop out the rubber grommet going through the body to antenna.
Remove the wheel and inner fender for easier access to antenna. You'll have to reach up to get to the big plastic nut where antenna meets body. Spin the nut off.
2 or 3 bolts on the antenna motor to car body and your done.
You probably only need the finial end and ribbon to repair it. I got mine from G.M.
Old Jul 19, 2004 | 10:03 PM
hngacurv's Avatar
hngacurv
I can barely reach mine from underneath the car, but removing it was much easier by just removing the rear wheel and fender well.
To Antenna on a 1986
