need lower shockabsorber sleeve measurement
Old Jul 19, 2004 | 11:49 PM
Stingraynut's Avatar
Stingraynut
Default need lower shockabsorber sleeve measurement
I got the measurement for the metal sleeve in the lower shockabsorber, for my 88, from this forum, a few months ago - I've tried using the search but it's useless - sometimes it shows only one post from me, maximum of 5.
Someone replied with the measurements about 6-8 weeks ago. I had my shocks reconditioned but one of the sleeves and rubber bush has parted company with the shock and I need to give the repairer the measurement again.
Its the sleeve that slides over the lower bolt on the rear wheel hub and has a rubber bush bonded to it that is then fitted in the lower eye of the shock absorber - I'd guess it's the same as other years - - I need the ID OD and length
Hope someone has one in their shed and can measure for me, thanks
S'nut
Old Jul 19, 2004 | 11:56 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Seems to me we did this a while back. OK, according to my precise measurements....
The shock these measurements come from is a KYB. :rolleyes The section of tube is a thinwall so the critical numbers are;
1-5/8" (40mm) long
21/32" (17mm) ID
3/4" (19mm) OD
-JRC-
Old Jul 20, 2004 | 02:15 AM
Stingraynut
Thanks Jr Riflecoach, YES, we did and I think it was you who gave me the answer.
I got new sleeves made but one of them recently popped off the recond shocky and was lost during the process of sending the shocky back under warranty, I didn't realise it was missing until I was asked for the measurements again this morning.
Thanks very much for coming back with the answer (again) much appreciated.
It seems everything I get done on my vette has to be done again and sometimes again - There are days when I think it's cursed, but I enjoy driving it very much - it's my daily driver so currently I am driving around with only 3 shockys - very hard to tell the difference as I got the shocks recond softer.
S'nut
Old Jul 20, 2004 | 02:28 AM
JrRifleCoach
Steve -JRC-
Old Jul 20, 2004 | 04:50 AM
Stingraynut
(and I've written it down in my 'Corvette Facts' book)
S'nut
To need lower shockabsorber sleeve measurement
