New Radiator
I have a new radiator on order thinking that it is rusted on the in side. is there other steps I should have taken before buying a new one?
Also whats the best way to flush out the insides of the engine before I install the new radiator
thanks
1) remove the t-stat... not much will get past it otherwise.
2) remove the block drains (knock sensors).
I don't think that brass or aluminum rads can rust...
you don't mention the year... what vintage?
And don't put "Dex-Cool", the orange stuff, into the engine. It will be ugly. There is no way of removing all residue of the green unless you rebuild the engine and replace all components that come in contact with coolant. If you do use DexCool, it will turn to jelly. icky.
Was the antifreeze brown or orange? It could be brown because someone mixed dexcool with regular antifreeze or someone put Bar's leak in it to plug a hole.
I just flushed my '90, had to pull the knock sensor to drain the block. You will have to pull the knock sensor(s) to get all of the coolant out.
thanks
Mixing "green" and Dexcool is ill advised, as expressed above. Only with the most thorough of flushes, drain plugs and all, would *I* consider filling it with the other. Good luck, and...
RACE ON!!!
Anyhow, its a longer process, but you really get everything out and truly have fresh coolant / water. Some forum member don't use tap water to refill, they use distilled water (less hard deposits = less contaminants, such as calcium etc.) but I have soft water in my area, so I don't worry to much. I actually took my radiator out and cleaned the outside too. Lots of leaves / dirt accumulate between the radiator and condensor. My car runs at about 203-204 degrees any time I'm driving over 15-20 mph. It'll never go above 222-223 even in traffic (Fan comes on and immediately brings it down to 209).
Hope this helps. Good luck. Pete.
