Question on intake plenum
Old Jul 22, 2004 | 10:47 AM
Don in Vermont's Avatar
Don in Vermont
Default Question on intake plenum
Hi All,
I want to replace my ERG valve. I have to take off the plenum. I have all the Torq bolts and the threaded fitting at the rear. How do I deal with the U shaped aluminum tubes on each side of the plenum ?
Thanks All,
Don
Old Jul 22, 2004 | 11:01 AM
loiq's Avatar
loiq
You should be able to get the plenum off without messing with the runners. It won't seem like the plenum will come off because they get stuck on there but with a little persuasion it should break free.
Old Jul 22, 2004 | 11:37 AM
Steel Blue 91's Avatar
Steel Blue 91
As stated, no real need to deal with the lower runner bolts. The first time the plenum comes off is the hardest. A dead blow hammer comes in handy at this time. Have a upper intake gasket set as you might damage the ones currently there.
Old Jul 22, 2004 | 12:53 PM
Don in Vermont
Default Plenum removal issue
Hi All,
Well, I got it off and the EGR valve is totally frozen and the pintel is broken off inside.
Thanks for the help
Don
Old Jul 22, 2004 | 01:03 PM
Steel Blue 91
Glad you got it off.
To Question on intake plenum
