Tunercat program
Old Jul 23, 2004 | 08:14 PM
Swampy's Avatar
Swampy
Default Tunercat program
Hi....I just downloaded the demo program from Tunercat. They say on their website that you can get the GM $42 calibration file off the internet but so far no luck finding. Do any of you know where I might find this file? I believe it will then you let you see what to expect to see while running the program....... Have any of you ever used this program with a 92 Corvette and if so how do you like the results?
It looks like a pretty decent program. What else do I need to run it with my laptop? I have a 2.8mhz Dell running XP. Should be more than fast enough. My only question is the cabling....... Tnx in advance for your input........Swampy and son.
Old Jul 23, 2004 | 08:43 PM
tjwong's Avatar
tjwong
Your demo program is good for 30 days its the real deal. After that you have to register it to continue to use it. It comes with the $42 ECM definition which is a very common GM ECM from the TBI trucks. It was used since the late 80s up until 1991. The ECM number that it is refering to is a 1227747 TBI system. If you want a couple bin files to open and play with email off list and I will email a couple files for you to play with.:
tjwong@qwest.net
