rough running '90
Old Jul 24, 2004 | 02:28 AM
white90conv's Avatar
white90conv
Default rough running '90
I have developed a hard to solve rough running problem. There are no codes but it idles poorly and sometimes is hard to start when hot. Always starts quickly when cold and is smooth until it goes into closed loop. It seems to have reasonable power at full throttle. If I reset the computer and disconnect the oxygen sensor, it runs fairly well but not as well as it used to.
I have checked or replaced the following -IAC motor, MAP sensor, TPS, coolant temperature, MAT, oxygen sensor, plugs, wires, cap, rotor, ignition module, knock sensor, egr valve. I also changed the computer to another used one. I have done an injector balance test. Nothing seems to change the problem. The compression is ok on all cylinders. The AIR flow to the manifolds shuts off when it is supposed to.
Block learn ends up at 108 which is low. It as if the car wants to run rich and the oxygen sensor then leans it out until it is so lean it barely runs. It's not like there is a great vacuum leak - the IAC seems to control the idle speed ok.
Anyone have a problem like this and if so, what is the solution.
Old Jul 24, 2004 | 03:08 AM
skateparkdave's Avatar
skateparkdave
St. Jude Donor '05-'06
Try getting a stethescope and removing the cup (that doctor puts on chest) and put tube tip on injectors one at a time and listen to your injectors for normal ticking. I had an injector that was stopping every so often and when the stick open it floods cylinder and causes a rich condition. But, this should throw a code.
In light of everything you've already checked I must ask, have you checked fuel pressure??
Also, have you cleaned your T.B.? A dirty one will cause a hard to start when hot condition.
Just my 2 cents. Good luck.
Old Jul 24, 2004 | 03:16 AM
white90conv
Fuel pressure is ok but I replaced the pump anyway (desperation). The TB bore and the IAC passage is clean. Is there anything else to clean in the TB?
Old Jul 24, 2004 | 10:39 AM
Sam Lam's Avatar
Sam Lam
Check the resistance of your injectors when the engine is cold and when hot. You should have 16 to 17 ohms resistance for each injector. Any values lower than 16 should be suspected for shorted coils within the injector. Hope this is helpful!
Old Jul 24, 2004 | 12:33 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You might check the EGR valve to see if it's leaking or stuck and use a timing light to see if engine miss coincides with missed flashes.
Old Jul 24, 2004 | 12:41 PM
skateparkdave
You also should check to see if injectors leak by checking if fuel pressure holds well after engine is off for a while.
So, your TB is clean..hmmm. Thats good. This should go without asking but you didn't mention so I have to ask. Did you replace fuel filter??
Well, I'm out of suggestions, but here's a thread bump anyways.
Oh yeah, check that egr like 65ZO1 suggests and I meant to suggest a timing check myself, Glad Jim mentioned the timing light.
Old Jul 24, 2004 | 08:00 PM
mikey whipreck's Avatar
mikey whipreck
I'd like to hear the solution to this problem... My car has almost the exact same symptoms (1985).
Old Jul 25, 2004 | 01:01 AM
white90conv
As suggeste, I did check the pressure with the engine shut off. It does drop - on the order of 10 psi in 1/2 hour. Of course there are other leakage paths - the regulator and back through the fuel pump.
I then kept the pressure up for an hour, disconnected all the injector electrical connections and cranked it. I could smell gasoline in the exhaust tips.
Then I dismantled the plenum and pulled the left hand injectors up and applied fuel pressure. In a half hour or so, the tips of all the injectors were wet with fuel although not enough to produce a drip. Is this enough to make the left bank excessively rich?
Old Jul 25, 2004 | 01:39 AM
skateparkdave
Hate to be the bringer of bad news, but it may be time for injector rebuild or new ones. 10psi pressure drop in a 1/2 hour is too much. The wet tips are a telltale sign. The fuel leaking is also is evaporating when injectors are out in the air, but when injectors are installed that fuel is just building up and sitting there in cylinder head causing hard warm start ups and reaking other havoc.
madvet.com has an Accel 24lbs/hr. set of 8 on sale for $299.00 and its what I got and am pleased so far. Ford SVO's are good also.
You can visit 65ZO1's site for links to injector replacements and solutions at:
http://www.geocities.com/jgkov/index.html
Good luck!
Old Jul 25, 2004 | 01:41 AM
65Z01's Avatar
65Z01
I don't think either the leakdown or the observed leakage indicates a leaky injector issue.
If there is a misfire in the left bank the ECM will see (through the O2 sensor) excessive fuel and lean out the trim; a misfire in the right bank should have no effect on fuel trim, right. Actually, now I'm thinking a leaking EGR valve would make the mixture too lean so you would be seeing BLM values above 128.
BTW, was it at idle that you see the BLM value of 108; what was the Integrator value?
Old Jul 25, 2004 | 01:47 AM
skateparkdave
I thought anything more than a few psi leakdown was a problem. It definetly caused mine. But I have to admit, I got a code.
Well, Jims the expert. Better listen to him My bad, I'll stand down.
Old Jul 25, 2004 | 01:24 PM
white90conv
Responding to 65Z01.
Wouldn't a misfire cause the ECM to think the system is lean? While there will be too much fuel in the exhaust there would be too much oxygen and the sensor measures oxygen.
A stuck open EGR valve would admit exhaust gases with little oxygen into the manifold. If this exhaust displaces fresh air and the fuel flow was the same, shouldn't itmake the system appear rich.
Please correct my logic if it is in error.
Old Jul 25, 2004 | 02:22 PM
65Z01's Avatar
65Z01
Well, though that leak down rate could indicate some injector leakage (or another issue) I don't think it is the cause of his problem (IMHO, I'm certainly not an expert here).
I may be wrong about the stuck EGR valve, to test for that condition, apply vacuum directly to the EGR valve at idle and observe the BLM value & Int changes.
Similarly, to check of the effect of a misfire, pull a plug wire on the left bank and observe those changes.
Right now I'm messing with a dead cruise control; be back in a short.
Old Aug 3, 2004 | 02:06 AM
white90conv
I took the car to a shop which measured the current flow through the injectors and detected three that were abnormal. I replaced the injectors and the problem is solved.
To rough running '90
