Wrong Serpentine Belt???
Old Jul 25, 2004 | 01:25 PM
Wayne88's Avatar
Wayne88
Default Wrong Serpentine Belt???
I'm changing my belt this afternoon.
The inner belt is the new one [outer belt old one].
Did they send me the wrong belt, or do they actually stretch this much.
Old belt says 'Gates' Micro V K060923
New belt says 'Gates' Micro V K060860
Thanks in Advance
Old Jul 25, 2004 | 01:46 PM
NightFlight's Avatar
NightFlight
Looks like the wrong size. The built might stretch a little over time, but I don't think they can stretch that much. If the old one fit snug/tight, I doubt you'll even be able to get that new on ...
Old Jul 25, 2004 | 01:48 PM
Wayne88's Avatar
Wayne88
Please Do Not Answer this question.
I just replaced the old one and its such a tight fit that the new one they sent me cannot be the right one.
This is the 2nd item I will send back from this same order.
They just lost a customer.
Old Jul 25, 2004 | 04:51 PM
ecna's Avatar
ecna
Assuming by the 88 in your name means it's an '88. The K060923 is the right belt. It's a common belt and you should just by it from a local auto parts store that has Gates. The part number is the size. the 6 means 6 ribs and the rest of the number is roughly length.
Old Jul 25, 2004 | 05:29 PM
Wayne88's Avatar
Wayne88
If what you are saying is true, then I have a problem.
There is no way on this earth that I can fit the smaller [new] belt on.
I am sure that all the pulleys [etc] are stock.
I'll have to call the supplier & deal with it.
Old Jul 26, 2004 | 12:44 AM
wb2dyb's Avatar
wb2dyb
Default Gates Belts
I ran into this with my LT-1. Had to finally brink old one to show them what I wanted, the cross reference book was wrong. Same with Front shocks on my 84. The Gabriel cross was very wrong...
-GC
Old Jul 26, 2004 | 01:12 AM
Southern Comfort's Avatar
Southern Comfort
I have had no luck with Gates belts. Try a Kelly Springfield belt...much better quality.
To Wrong Serpentine Belt???
