windshield wiper problem.. please help!
Old Jul 26, 2004 | 08:35 PM
SuperDave90C4's Avatar
SuperDave90C4
Default windshield wiper problem.. please help!
well i got another problem.. i turned on the winshield wipers the other day.. worked fine for about 20 seconds and they stopped sticking straight up... as i wiggled the turn signal stalk i finally managed to get them to work down into there rests... now when i turn on the left blinker they want to start working... should i replace the stalk? wiper switch? has anyone had this problem before? also if i have to go into the steering column how do i disable the air bag... i really dont want to get hit by that thing... any help is appreciated since its supposed to rain here all week
Old Jul 27, 2004 | 11:16 PM
SuperDave90C4
please
Old Jul 28, 2004 | 12:33 AM
bogus's Avatar
bogus
I did a tech article on this back in January... I have no idea if it's available, tho..
however, it really isn't that hard.
1) remove the SRS fuse.
2) using a T15 (I think) remove the airbag
3) loosen the big bolt that holds the wheel on.
4) use a wheel puller to remove said wheel
5) carefully compress the coil for the airbag. it is position senstive, but only goes in one way.
6) using a lock ring compressor, remove the lock ring.
8) that's all you do with the column in the car, it gets easy if you remove the column and do the rest on the bench. A vise is required!!!
9) two bolts hold the column to the dash, remove them.
10) two bolts hold the column to the firewall, remove them.
11) 1 bolt holds the column to the steering shaft. it is reached from the top, past the master cylinder.
12) disconnect all leads and remove the column from the car
13) dig in!
14) everything is stacked... turn signal, ignition, etc...
15) you will want to get all new parts...
a. turn signal switch
b. multifunction switch (highbeams/wipers/signal activation)
c. tilt wheel rebuild kit (new pins and spring)
16) replace accordingly.
17) reverse for reassembly.
It really isn't that hard... just don't cut the yellow wire.
Expect it to take 3 hours the first time out.
If you have any questions, I am sure I can help... I did this back in january - twice - before I got all the right parts.
Old Jul 28, 2004 | 08:06 PM
SuperDave90C4
thanks!!! if you were near houston i would buy ya a beer!!!
To windshield wiper problem.. please help!
