Temp. Reducing Additives
Old Jul 27, 2004 | 05:39 PM
CAJUN C4's Avatar
CAJUN C4
Default Temp. Reducing Additives
Anyone Use "40 Below", Redline "Water Wetter".or Royale Purple? Mine doesn't overheat but could use a liitle "Coolness" Down here in Cajun Land.
Thanx
Old Jul 27, 2004 | 05:59 PM
hngacurv's Avatar
hngacurv
Old Jul 27, 2004 | 06:31 PM
Wayne88's Avatar
Wayne88
I heard Water Wetter is pretty good.
But I never used it, I don't need it.
The highest mine got this summer is 216.
My chip turns on the main fan at 212.
Old Jul 27, 2004 | 07:29 PM
guywade's Avatar
guywade
Default redline water wetter
i use redlines water wetter and it cooled my engine about 10 to 15 degrees , and my cooling system was perfectly ok before, just thought i'd get the temps down a bit by the way i mixed 1 water wetter with 50/50 in radiator
Old Jul 27, 2004 | 09:00 PM
CFI-EFI's Avatar
CFI-EFI
If someone knows of an additive package that doesn't work as well as Water Wetter, I need to know about it. For the additive package, I have a standard 12 oz bottle in my cooling system with only tap water. On a 40 mile trip, in 95* weather, at 65-70 mph, I couldn't get my engine over 177*.
RACE ON!!!
Old Jul 28, 2004 | 04:13 AM
ninetyfivevette's Avatar
ninetyfivevette
I put the Royal Purple in mine just yesterday after flushing the cooling system to prepare for a road trip taking me all the way through California, which is very hot this time of year, so I'll know shortly how it performs. So far mine has not gotten above 182F, but here in Seattle, the weather has been cooler (not counting Saturday where it reached 100F!!!).
The interesting thing about Royal Purple is the directions only call for 3-4 cap fulls per 1 gal of water/coolant, not an entire bottle.
Old Jul 28, 2004 | 08:11 AM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I have not used anything in the '96, but used Water Wetter in the '79 and it brought temp down about 15 degrees. The C3s (for those who don't know) are notorious for running really hot and making the cockpit feel like an oven! C4s are a nice change....
Old Jul 28, 2004 | 08:24 AM
comp's Avatar
comp
they only work if runnning straight water, the draining and replacing with 50/50 will help And used distilled water with the anti-freeze (the additive's are water softeners)
Old Jul 28, 2004 | 09:46 AM
vader86's Avatar
vader86
Water Wetter, but it works best if you have a higher water-to-coolant mix in the radiator.
Old Jul 28, 2004 | 09:51 AM
CAJUN C4's Avatar
CAJUN C4
Great....What Ratio of Anti-Freeze to H2O should I run?
Old Jul 28, 2004 | 09:59 AM
vader86's Avatar
vader86
Since its about 5F cooler than Hell down here, you could get away with 100% water until December.
But I wouldnt run more than 70/30.
Old Jul 28, 2004 | 10:07 AM
CAJUN C4's Avatar
CAJUN C4
You think with plain water corrosion would be an issue?
Old Jul 28, 2004 | 10:48 AM
chriswtx's Avatar
chriswtx
I use 20%antifreeze, the rest distilled water and 2 bottles of water wetter. You can get water wetter at Pep Boys or Advanced auto.
Old Jul 28, 2004 | 10:54 AM
black_89_vette's Avatar
black_89_vette
I have ran straight distilled water with a can of 40 below. My temps dropped pretty good, but this was also after I replaced a fan motor.
I have a bottle of Water Wetter and have yet to put it in, call me lazy.
Old Jul 28, 2004 | 11:14 AM
comp's Avatar
comp
the distilled water is "soft" it's the minerals in water that cause the problem
Old Jul 28, 2004 | 01:25 PM
nobodyunknown's Avatar
nobodyunknown
This thread is timely for me.
Im working on a 86 Monte Carlo with a 454 in it.
Its running about 220 now.
Im adding water wetter today & will have a report tommorrow from the owner.
I checked water wetter & 40 below.
$40 below requries a certain type of antifreeze & since I dont know what kind is in the car, I didnt choose it.Also it requres distilled water.
Also 40 below is $20, Water wetter is $7.You can use any anti freeze & regular or distilled water.
Old Jul 28, 2004 | 01:32 PM
brookman's Avatar
brookman
There are a couple of misconceptions in this thread.
Anti-freeze actually does not cause the car to run cooler. Water itself is the best coolant. The problem with running straight water is that its' lubricating properties are not as good as the water with the anti-freeze.
The other benefit to using anti-freeze is that it raises the boiling point of the water.
One last comment true Distilled water is pure. There should be no minerals in the water.
To Temp. Reducing Additives
Old Jul 28, 2004 | 07:34 PM
CFI-EFI's Avatar
CFI-EFI
The lubricating properties are the reason I use Water Wetter. I started using it when I was concerned with running too hot, and have continued. Now, it doesn't run hot enough, but it sure cools down quickly between rounds at the track.
RACE ON!!!
Old Jul 28, 2004 | 07:59 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
I've been using water wetter. Seems to work. But in bumper to bumper traffic hard to tell.
Old Jul 28, 2004 | 08:09 PM
McShagger's Avatar
McShagger
Water wetter works best if you do NOT use coolant. Waterwetter and distilled water helped keep my car cool at the track.
