Oil Pumps???
Old Jul 26, 2004 | 08:42 PM
GS345's Avatar
GS345
St. Jude Donor '11
Default Oil Pumps???
I am about to start final assembly on my 396 LT4. Which oil pump are you guys running? Im going to get a Canton pan but not sure about the pump.
thanks,
jeff
Old Jul 26, 2004 | 09:21 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
thanks,
jeff
I'm running the stock pan so I stayed away from a high volume pump, just got a high pressure one. But with your pan you could safely use a HV one. I used a Melling, but there are other good ones too. I would also recommend a hardened shaft w/ steel coupler and More Performance's LT1/ 4 oil pressure saver. Also replace the drive if you haven't already.
Old Jul 26, 2004 | 09:47 PM
RichS's Avatar
RichS
I used a Melling HV/HP with a Canton pan.
Old Jul 27, 2004 | 02:01 AM
h rocks's Avatar
h rocks
thanks,
jeff
Much debate over this question...check out the archives, you will have to draw your own conclusions.
Based on personal experience and that of two close friends, I would use nothing more than the Melling 10% over pump. Frankly, if I were starting over, I would likely use a standard flow Melling. All of us that have had problems, had large capacity Canton pans, and heads that had the return drains machined and polished.
To Oil Pumps???
