Boost air temp and air sending unit
Old Jul 26, 2004 | 10:44 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Boost air temp and air sending unit
Anybody tried using the stock air sending unit to determine the boosted air temp? is it fast enough for short bursts? I tried mine last weekend and only saw a 5 degree increase. also would the temp increase be related to the restrictions in the system? a free flowing system might have less then a restricted system? I trying to determine where, at what boost to inject alcohol/water..........with this puny p600b I'm only seeing 9 psi at supercharger redline.....well maybe 10 psi.
Old Jul 27, 2004 | 01:41 AM
BAM92's Avatar
BAM92
As for where to set the water injection, you will probably have to use a diagnostic software to check KR count. Use injection to eliminate KR's so as not to retard ignition. I have not set mine up yet so I am also interested in this.
Old Jul 28, 2004 | 01:21 AM
Mo_Bandy's Avatar
Mo_Bandy
Hi lead I responded to your other thread although it was slightly differnt form this one...
I as a rough "guestimate" us the MAF readings...
The highest NA MAF readings I got at say 5500 rpms was like 27.7 lb/min the highest I got supercharged on a good day full foot to the throttle nad no spark knock retard was 48.7 lb/min
If you take the 48.7 / 27.7 you get about 1.75
14.7 * 1.75 = 25.725
25.725 - 14.7 = 11.025
figure about 85 % efficiency 9.4 boost...
another way would be to calculate your CFM's
again using the maf sensor.. a NA estimates about 480 CFM
cu *rpm*.5*VE /1728 = CFM
350 *5500*.5 *.85 = 473.45
473.45 /14 = 33.81 Normally aspirated...
Lb/min * 14 = CFM
52.2 *14 = 730 cfm supercharged
730 / 473.45 = 1.54
14.7 *1.54 = 22.6 -14.7 = 7.93 pounds of boost...
In most cases I wouldnt think you would need water injection below 4-5 pounds of boost.... As BAM 92 said look at the knock counts that would guide you...
hope this helps, I use these just as a rough estimate .
Mo
To Boost air temp and air sending unit
