From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
You're going to listen to someone who drives a Ford? He's full of crap.
I had vowed to not get into anymore header discussions, but this is a new wrinkle. I couldn't resist.... Check out headerdesign.com You'll have all the evidence you need.
I started of with 1 3/4 Slp shortie headers and changed to 1 3/4 TPIS long tube headers. What a difference. Car revved so much quicker and pulled much harder on top end. Some have hp figures to back this up. I believe there is usually a minimum of a 15hp difference depending on your mods. How many race cars do you see with shorties?
I don't know about Mustangs, but on CORVETTES, you are correct, sir. LT headers *will* provide a significantly higher gain than shorties. In fact, I've heard it said that the stock exhaust manifolds for our cars (LT1/LT4, anyway) will flow as well as shorties, if not just a little less. Tell your buddy to stick to 'Stangs.
I think, technically, and to the extreme, that your buddy is right. For peak horsepower, only. If your engine rpms will never drop below 5-6000 rpms, I think the short tubes, properly tuned can make more horsepower. Look at the headers on a AA fuel dragster or a funny car. However, for anything you're actually going to DRIVE, long tubes, have a much broader torque range, that will provide an increase in usable performance. If you have a VERY wild engine and want to make the biggest number possible on a dyno, shorties are the way to go. But if you're headed down to the local "In N Out" store for a six pack, shorties suck.
Well, since you bud is a Stang owner, agree with him and urge him to install shorties onto his street engine.
Indeed top fuel doesn't even run true headers, they just fire directly from each exhaust port into individual pipes. But with 7k CHP on tap do they realy need to tune the exhaust!
The power band to which the header is tuned is determined in part by the length of tubing from exhaust port to header collector. Remember the lesson taught the C4 TPI intake; the principle is the same...ram tuning. It's all about reversion pulse frequency and intensity. All that is necessary to avoid low end torque loss it to prevent reversion from weakening the charge, which the late L98 D-port heads tend to do nicely.
So, for your debate with your buddy he needs to specify the power band before the issue can be resolved.
