How to test injectors?
Old Jul 27, 2004 | 06:15 AM
conv90's Avatar
conv90
Default How to test injectors?
I have to measure resistance but I really don't know how..
Think to explain it to a child (i have 0 knoledge on electronics things...)
Yes I have a voltmeter (the thing with attached two wires and a big selector on the middle)
I think I have to use the selection on the ohom side (resistance = ohoms right?)
Where I have to put the two stings? The car should be with the ignition ON? the engine started?
My car is a 90 with stock 22lb/h injectors
-Beppe-
Old Jul 27, 2004 | 08:29 AM
mos90's Avatar
mos90
your ohlm readings should be 14-16. you do not need the car runnng or ignition on but the injectors test better when warm. set your voltmeter to 200 ohlms. take the injector harness off the injector and it doesnt matter what end of the voltmeter you put where. if any injector is out of range change them all. this test will only check the mechanical part of the injector, they can all test good and you could still have a bad spray pattern. if they test good i would still send them out to be cleaned and blueprinted. tpis does this for about $8 per injector.
Old Jul 27, 2004 | 08:37 AM
conv90's Avatar
conv90
Thanks, but I'm a stupid on this subject.
Let me know if I understand:
I take one of the 2 ends of the voltmeter (no matter wich one, the red or the black on the voltmeter are the same..)
Where I have to put this end? on the body of the injector?
on the harness? Which harness'? there are 2 wires comes from the top of the injector..
Sorry Im so stupid on this..
-Beppe-
Old Jul 27, 2004 | 08:46 AM
shotchkiss's Avatar
shotchkiss
Unplug the harness from the injector, the injector will have 2 contacts on top of it. Touch the wires from your voltometer to the contacts on the injector.
Old Jul 27, 2004 | 08:47 AM
mos90's Avatar
mos90
on the top of the injector there will be 2 pins, put the black on 1 end and the red on the other. you will need to take the injector harness off the top of the injector then you will see the the 2 pins.
To How to test injectors?
