Rear lowering kit issue
Was the gap equal before lowering bolts installed ?
I used alloy ready rod for mine and I had to lower one side more than the other to obtain the equal gap. With the ready rod cut at 11 inches I had any adjustment required.
Keep us posted
Keep us posted
The only thing I can think of is that I installed the poly bushings in a different orientation on the passenger side, and maybe now they are not compressing like they used to
. Maybe I'll disassemble the passenger side again and redo it. It just doesn't make any sense to me
Or is this a really stupid idea because the spring will only go on one way?
BTW, after lowering mine, I have the same issue (driver side is lower and the passenger side). You will definately want to be careful how you preload each side because if they are too out of whack, I would think that would change the corner weighting in the rear enough to make your handling erratic, at least that would the the case with coilovers, not sure how that translates the stock monoleaf.
Good luck!
Perhaps with the longer bolts, the compression rate is not as well defined since there is less tension on the spring than GM planned for. Just a thought anyway.
You didn't say wether you have touched any other part of the suspension. It sounds like it may be too tight or one of the control arms may be binding, stopping the suspension from moving freely.
Just a thought.
Good luck.
After I installed the lowering bolts, I had to thread the driver side bolt about 4" up but, the passenger side was only threaded 1/2" up. I removed checked and readjusted everything to make sure all the bushings were positioned correctly but, the two sides were still off.
After a week or so of driving and adjusting to get the ride height perfect on both sides, I had the Vette aligned. Also, remember to take all measurements with a full tank of fuel because the weight of the fuel will make the rear end sit lower.
That is EXACTLY how my rear bolts look
. The problem is that with that setting, the rear is really not lowered at all. How much gap do you have in the wheel well above the tire? I have approx 3 inches.
It is lower than before as you can sort of see from this before picture. After I lowered it the rear sits 1/4" higher than the front with a full tank of fuel and raises slightly as the fuel empties.
I don't think that you can use the gap (distance between top of wheel and bottom of well) as a good measure of 'lowering' the car.
When I did mine I measured three things:
1-the gap
2-distance from wheel center to bottom of well
3-distance from the bottom of the body/frame(where the side panels turn to a 90 degree angle) to the ground
I dropped my rear 1" to start. The body measurements changed, but the gap stayed the same
.I had to tweak that POS 3-5 times to get it right, and it still isn't!
Just remember ( and I may be wrong), to keep the distances from the body to the ground the same. If they are not, you are overloading one wheel, and that will kill your handling!
I measured the distances from the body to the ground in the front, added 1/4", than lowered the back sides to match the front + 1/4".
Looks good, but still needs to be lower!!
